Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 19th September 2014, 08:25 AM   #811
syklab is offline syklab  United States
Hi Tibi,
Try 1000pF and 2200pF 500V silver Mica on C11 and I like the 2200pF better, the base handling is better.Will start on the the laser mod this weekend. I will use film cap for 1nF and 100nF, cannot use silver micro there since I cannot get the 100V 1000pF, only 500V is available but it is too big for that job.
Old 19th September 2014, 08:49 AM   #812
tvicol is offline tvicol  Romania
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
On laser mod a 100nF MKP is my recommendation. Vishay 1837 will perform excellent.
On pin mod it is mandatory to use a 1nF silver-mica.
CD15FA102JO3F - CORNELL DUBILIER - CAPACITOR SILVER MICA 1000PF, | Farnell UK
Tibi
Tibi
Vicol Audio
Old 25th September 2014, 06:00 PM   #813
Fabian85 is offline Fabian85  Germany
Does anybody have the wiring diagram of the transformer? Vicol Audio site is down right now
Tried to hook mine up and it got really hot. Colors on primary are black / white / yellow,
marking says Pri:0,115V,230V/50Hz - yellow/blaack/white.
Old 25th September 2014, 07:51 PM   #814
shizaudio is offline shizaudio  Russian Federation
Hi, Fabian85,
find it here
Old 26th September 2014, 06:22 AM   #815
tvicol's Avatar
Have a look on this post Shigaclone MKII Black - The builders Thread
Tibi
Old 26th September 2014, 10:00 AM   #816
Psu working, right now i am checking my IC solder points.
Should there be a connection (continuity tester says there is one) between LA6541 Pin 10 and 11?
Old 26th September 2014, 01:13 PM   #817
tvicol's Avatar
There is no continuity between pin 10 and 11 on LA6541.
Please check your soldering.
Tibi
Old 26th September 2014, 01:23 PM   #818
Sure? I checked all my pins, absolutely no soldering bridges on all ICs. But there seems to be a VERY small bridge under the solder mask going from trace 11 to 10. Shall I cut it?
Old 26th September 2014, 01:40 PM   #819
Removed all solder from the pins and liftet them. Still a connection where, according to the schematic there should not have been one. As said before, I checked the PCB and saw a very tiny bridge on the PCB that somehow did not fit Tibis otherwise so perfect routing.
Check below pin 10 and 11 where the solder mask has been scratched. There was the connection that caused pins 10 and 11 to be "connected". It is no longer. Connections now are as the should be according to the schematic. Can I safely power on now Tibi? ;-)
Fabian
Old 26th September 2014, 01:53 PM   #820
tvicol's Avatar
I can confirm that there is no connection between pin 10 and 11.
Engage !
Tibi
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
