Shigaclone MKII Black - The builders Thread - Page 45 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th June 2014, 06:53 PM   #441
Erik van Voorst's Avatar
I got the puck working.
It took a bit of sanding.
I used grain 100 and 280 cut a very thin piece of sanding paper couple of mm and sand the inner alu pen stroke bij stroke all around...very tedious work but it pays of. (Approx 20 minutes)
Finally a bit of vaseline and you can lower and remove the puck without the slightest stress on the spindle.
Good work TIBI
To baldly go where no man has gone before................(James Kirk)
Old 19th June 2014, 06:53 PM   #442
Turbon is offline Turbon  Sweden
Turbon's Avatar
Originally Posted by tvicol View Post
I had a look again and seems to be 2N4403 - ( marked PJ66)
I'm not sure if R46 is proper soldered.
And please make again few high resolution pictures. Try to use macro when you take pictures and get better focus. I want to see ribbon connector and ic's pins.
Tibi
Hi, I'll see if I can borrow a macrolens.
Had a look at every solder at 10X and resoldered everything that looked suspicious including R46. Didn't find any really bad ones.
Measured the J1 connector. Is from the text J1 CD Deck no6 and no8 supposed to be shorted?
You see, a schematic would be useful to have...
Erik, good work
Old 19th June 2014, 07:27 PM   #443
My turner tried to make it perfect. It is to tight that will not allow air to enter in spindle gap.
Shave the aluminum a little and will work just fine.
Tibi
So there is such a thing as too perfect..
Old 20th June 2014, 06:10 AM   #444
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
Indeed, the inner puck is so tight than will act like a piston in a cylinder and will not allow air to enter or get out, so you need to apply force which may affect turntable.
Interesting is that I have several mechanics on which such puck work easily. It is a tolerance mentioned in datasheet.
Thanks Erik, this will help others to get a better puck.
Tibi
Vicol Audio
Old 20th June 2014, 06:32 AM   #445
tvicol's Avatar
Erik, good work
No short between J1 pin 6 and 8.
Tibi
File Type: png Screenshot from 2014-06-20 09:30:24.png (193.8 KB, 343 views)
Vicol Audio
Old 20th June 2014, 07:11 AM   #446
Turbon's Avatar
Tibi
No, but between 9 and 11. So if one counts wrongly as I did with pin1 furthest away from the IC one could believe it was 6 and 8.
I compared the laser on new and old shiga and they seem to be equal in strenght. So the laser seems to work - at least the ld part. I assume that the pickup circuits are the same on old and new shigas? Is the attachment about the new one?
Old 20th June 2014, 07:13 AM   #447
Turbon's Avatar
Tibi
The new puck fits better on my old shiga.
Old 20th June 2014, 07:14 AM   #448
Yepp, I had a batch of mechanics which were Identical but I can remember That I had to correct the inner whole of a Marigo cd in order to fit while my friend could use it straight away.
The same diameter deviations can be found on cd.!!...Redbook Heritage brrrrrrrrr
Old 20th June 2014, 07:23 AM   #449
tvicol's Avatar
Yep, attachment is the MKII.
Did you tried with a different mechanic or another ribbon cable ?
Some ribbon cables will not make contact unless you clean them.
Tibi
Vicol Audio
Old 20th June 2014, 08:15 AM   #450
Turbon's Avatar
No, this is the only standalone mech I have until the one from you arrives.
But the schema will keep me occupied for a few hours tonight
I will check the ribbon cable very closely as well.
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
F3 Builders Thread Melon Head Pass Labs 523 31st May 2014 03:05 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
Copyright 1999-2017 diyAudio
