Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 17th June 2014, 02:53 PM   #411
Turbon is offline Turbon  Sweden
Turbon's Avatar
Originally Posted by tvicol View Post
See here Danzup post Shigaclone MKII Black - The builders Thread
I do not understand this question "Is flatcable enough as motorcabling?"
Tibi
Hi Tibi.
The kind of flatcable you sent in the kit. Is it good enough to use between J2 and the motor?
Thanks for the link to danzups post - I don't understand how I missed it? Probably tried to hard reading thru all posts...
Old 17th June 2014, 03:59 PM   #412
tvicol is offline tvicol  Romania
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Originally Posted by Turbon View Post
Hi Tibi.
Yes, it is a very good cable. Use it.
This thread become big and my friend jazz35 is working to make a concise document.
Tibi
Vicol Audio
Old 17th June 2014, 06:07 PM   #413
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
This is what you are looking for Dimitri
To baldly go where no man has gone before................(James Kirk)
Old 17th June 2014, 06:32 PM   #414
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Awesome thanks a lot Erik
Quick question. Is the motor shaft snug enough in the 2mm hole?
I got a new meter and I measured the motor shaft at 1,85mm
I am making a turntable one out of ebony, currently working on an MDF test
Too many projects... so little time...
Old 17th June 2014, 08:31 PM   #415
Turbon's Avatar
Hi, just to be sure... Is the J2 pin closest to the 4 pads ground or 8v?
Old 17th June 2014, 09:30 PM   #416
Turbon's Avatar
Found it...
Old 17th June 2014, 09:36 PM   #417
Turbon's Avatar
Default Sad day...
First. My transport seems to be broken. Several teeth are missing on the longitudional rack which moves the laser back and forth.
Second. If I help it beyond the damage it goes inwards and starts pounding the end switch. It does it until I turn power of. I might have missunderstod the cd door pins. Are they 1 to 1, 2 to 2 and 3 to 3?
A picture of the broken transport...
Please advise.
Old 17th June 2014, 09:48 PM   #418
dimkasta's Avatar
Please advise.
You got the motor cables the wrong way. Just reverse them
Old 17th June 2014, 09:52 PM   #419
Turbon's Avatar
Ok, thanks Dimitri. You mean all of them as 1 -> 6, 2 -> 5 and so forth?
I'll test this tomorrow - sleeping time... I will probably dream of tiny clips...
Old 17th June 2014, 10:01 PM   #420
dimkasta's Avatar
Yeah I know it sucks. I had the same issue day one...
Yes if the sequence is 1-2-3-4-5-6 reverse it in one side of the cable like 6-5-4-3-2-1
I hate those damn clips too
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
