Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 3rd December 2017, 12:18 AM   #1611
hartbigsky is offline hartbigsky  United States
Hi Tibi,
So do you recommend mini-regs [adj] for V1-V2 or just LT1086 for best performance? I do have salas reflecktor-d's also. If I use reflector-d is there a recommended wiring configuration. Can I use mini-reg on V3-V4 and reflector-d V1-V2 since you can't mix fixed and adj mini-regs? Thanks for time and info!
best regards,
Steve
Old 3rd December 2017, 10:18 AM   #1612
tvicol is offline tvicol  Romania
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Hi Steve,
V1 = V2 = V3 = V4 = 5V
Make sure that voltage difference between them is under 100mV.
For example V2 can be 5,050V and V4 = 5,140V, but not 5,200V or 4,900V.
V1 - power laser and Vref section
V2 - power HF analog signal processor LA9242
V3 - power clock section
V4 - power digital signal processing section LC78601
Miniregs can be used in V2,V3 and V4 positions. For V1 you need a more current capable regulator, like LT1086-5. Please note that minireg in V2 position do not make much difference, at least in my system...
If you look for madness resolution, than in V3 position use a Salas D reflector.
For V1, you may use Salas as well. Again resolution is enhanced. This tighten bass even more and you hear everything. Some people may say is too much ... ;-)
If you intend to bring Shiga MII to very high-end top killer, than a Dexa Neutron and Duelund Silver Cast - for C8 -are a must.
Tibi
Vicol Audio
Old 3rd December 2017, 10:56 AM   #1613
tvicol's Avatar
Hi Steve,
For V1, you may use Salas as well. Again resolution is enhanced. This tighten bass even more, extend instruments decay, add more harmonics and you hear everything. Some people may say is too much ... ;-)
Tibi
Vicol Audio
Old 5th December 2017, 12:17 AM   #1614
sthcoaster is offline sthcoaster  New Zealand
Originally Posted by carolus View Post
Hi Clayton.
Good choice with your "Neutron Star 2 Audio Reference" (incl.the PSU).
It's fine music ...
Congrats.
Karel
Thanks Karel
As with all these things ... when you improve one part of your signal path it just highlights a weakness elsewhere !! One day I may treat myself to the Dueland Cast in C8 to go with it.
Clayton
Old 7th December 2017, 02:57 AM   #1615
Thanks for information on V1-4! I am building using the high end components. If I use Salas D reflector do you recommend to go directly to V-out and gnd on V_ pcb regulator
pads as it has its own transformer?
Steve
Old 7th December 2017, 06:20 AM   #1616
tvicol's Avatar
Steve
I'm not sure that I have understand what you mean. However, I recommend you to use a separate trafo for each Salas, or at least use a trafo with with separate secondary winding's.
Use a single point for GND, for all Salas regs, at the main board power input.
If use a metal enclosure, ground the enclosure from the output S/PDif.
Tibi
Vicol Audio
Old 9th December 2017, 01:10 PM   #1617
Robert Poublon is offline Robert Poublon  Netherlands
Default SPF 101 16p old version for sale
To all Shigaclone buiders,
I have for sale 1 SPF 101 16p old version, new and unused.
If you are intersted mail me: poublon@home.nl
Robert
Old 10th December 2017, 07:44 AM   #1618
tvicol's Avatar
Bronze CD puck. Stunning improvement.
Tibi
Vicol Audio
Old 11th December 2017, 04:11 AM   #1619
Hi Tibi,
I am trying to find information about the 2.5V regulator ADP151-2.5, it is listed with option components if used but I can't find anything regarding it's use. Can you fill me in please or point me in the right direction. Regarding my inquiry about salas d reflector use, my question was regarding 5V out. Can I input at V3 pads on shiga pcb ?Thanks!
best regards,
Steve
Old 11th December 2017, 07:21 AM   #1620
tvicol's Avatar
Hi Steve,
ADP151-2.5 is there to provide a very stable Vref=2,5V for laser PIN detector. In case you want to implement this, you need to add R65=1K, C68 and C69. C68 and C69 must be at least 1uF. At this value any MLCC is highly piezoelectric, please mount them vertically to minimize this effect, or use a tantalum on C68.
Salas D reflector can be used on any V1=V2=V3=V4=5V. Single condition is to tune them to output under 100mV difference voltage. You may want to load Salas with a 1K resistor.
Tibi
Vicol Audio
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
