Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 1st November 2017, 09:57 AM   #1591
tvicol is offline tvicol  Romania
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Originally Posted by spartan View Post
Hi Tibi,
can you tell us more about the remote control? Price, installation, etc.
Bluetooth remote control (called Bluthor) is based on a module that was developed by us several years ago.
The module can be used with any CD player that have or not have remote control, adding bluetooth remote control feature.
The main idea behind Bluthor is that he make use of REED relays across any existing push-button to simulate button press.
There will be two modules. One for Android and one for IOS.
Applications are available for download from Quantum web-page.
Apple make use of smart BLE technology, therefore we had to use different bluetooth modules.
Installation on Shiga MKII is straight forward, as we have already designed Shiga MKII for Bluthor. If you look on main display board you'll see that under each push-button are two small holes. These are designed for Bluthor connection via wiring.
You may power Bluthor from same power supply as Shiga MKII. Bluthor have his own regulator and accept unregulated power in range of 8Vdc to 15Vdc.
On 1st December Bluthor price will be 59 euro. Afther that 79 euro.
Bluthor is already integrated in Quantum CDT and people love it.
Brgds,
Tibi
Vicol Audio
Old 1st November 2017, 10:02 AM   #1592
Fabian85 is offline Fabian85  Germany
Nov or December? Webshop says 1st December.
Old 1st November 2017, 10:03 AM   #1593
tvicol's Avatar
1st December, Sorry !!!!
Vicol Audio
Old 7th November 2017, 06:58 AM   #1594
tvicol's Avatar
Gorgeous Shiga MKII high-grade implementation by an audiophile fellow.
Tibi
Vicol Audio
Old 11th November 2017, 07:57 AM   #1595
tvicol's Avatar
Quantum high grade got some very fine company and I must say that is a top of the top performer. Really proud.
Vicol-Audio - In action ...
Tibi
Vicol Audio
Old 17th November 2017, 09:23 AM   #1596
sthcoaster is offline sthcoaster  New Zealand
Default Shiga Black "Temporary" Home
Hello all
Sharing some pics of my Shiga Black "Temporary" enclosure. Inverted commas temporary because I know that temporary is likely to be a long-time Its not perfect but then that gives me greater incentive to make the "permanent" enclosure. It could do with some sanding and a spot of varnish and a bit more tidying up but for now I'm going to leave it alone and finish some of my other projects.
The top is a two layer construction using faux slate for the laser cutout and then real slate for the disc cutout. There is more faux slate on the bottom to help with mass loading.
I can't remember where the box came from - possibly charity store find?
Jupiter Copper Foil Paper & Wax Cap in C8
NewClassD Neutron Clock and PSU
Vicol miniregs in V3 and V4
All the recommended mods to the laser
Cryo treated gold plated phono for output
Things left to do
- LT regs in V1 & V2 and add separate PSU
- change toroid to r-core
- LT regs in PSU
Cheers
Clayton
Old 17th November 2017, 09:51 AM   #1597
tvicol's Avatar
Looking great, Clayton !!!
Tibi
Vicol Audio
Old 28th November 2017, 02:54 PM   #1598
Robert Poublon is offline Robert Poublon  Netherlands
Hi Tibi and Dimitri,
Revering to thread #193, which of the two bastards should be replaced with what. Left 100nF Artronics Film PET and right 1nF Silver Mica? And did you crush the ceramics with a small plier like Dimitri suggested or did you desolder them. Which points did you use to solder the replacement parts?
Robert
Old 28th November 2017, 04:01 PM   #1599
tvicol's Avatar
I desolder all ceramics.
Now my latest modifications implemented in Quantum/Shiga MKII high-grade are:
- over laser I use a combination of 1nF silver-mica + 100nF Vishay 1836
- for pin chip reference voltage I use 1nF silver-mica
- Vcc decoupling I use 100nF Vishay 1836
- over bias monitor potentiometer I use 1nF polystirene or silver-mica
Tibi
Vicol Audio
Old 28th November 2017, 04:09 PM   #1600
Hi Tibi,
Thanks for your reply! But which of the two ceramics is PIN and which is Vcc decoupling? And did you solder them on the ribbon or on other places?
If other places, can you indicate them?
Robert
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
