Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 28th February 2017, 09:20 PM   #1511
czitta is offline czitta
Default shiga mk2 finished
Hello Tibi,
my shiga is finished and playing - added some impressions.
The sound is very good - lively, precise and musical - better than the flac files from NAS, played with a Cambridge streamer.
DAC was in both cases a DDDAC1794 and the amplifier was a tube one, the UCL11 from Frank Blöhbaum with 8 Ohm resistor as load working perfect as headphone amplifier. Headphone was AKG 812 and believe me you hear every detail with it - thanks to the shiga.
Greetings from Austria and best regard
Christoph
Old 28th February 2017, 09:28 PM   #1512
sthcoaster is offline sthcoaster  New Zealand
Great set of photos Christoph. I very useful reference/comparison.
What size is your enclosure? The top plate over the spindle and laser mech is different to others that I have seen and different to the template that is provided - interesting to see.
Nice to see a close-up of different implementation of the buttons - I have been puzzling about this for myself
Enjoy!
Clayton
Old 28th February 2017, 09:57 PM   #1513
Enjoy!
Clayton
272 mm x 211 mm x 60 mm - the aluminium casing is from China - the same I used for the DDDAC 1794 and similar to the UCL 11, which is bigger, but the same style
design was done by me - sketch added in a previous post (only position of display changed)
all the holes are drilled or done with a jigsaw and file, except the 125 mm hole in the top plate, which was cut with water jet
Old 28th February 2017, 11:32 PM   #1514
tomw is offline tomw  Australia
Wow, that's beautiful. I will upload my pics soon but my attempt is amateurish in comparison.
Old 1st March 2017, 06:37 AM   #1515
tvicol is offline tvicol  Romania
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Beautiful work, Christoph !
Tibi
Vicol Audio
Old 1st March 2017, 06:59 AM   #1516
Fabian85 is offline Fabian85  Germany
After a long time finally nearly finished my shiga... lots of metal work had to be done. Seperators are painted steel to get more weight, transport pickup is done on 5 axis cnc mill from one aluminum block. The whole construction is sitting on custom made springs to balance rotation forces of the cd. Wanted to make the transport a little more compact so used a 1U case from modushop.
Still on plan:
- adding v1/2, board is already installed but not 100% finished. Low noise cap multiplier.
- upgrading the clock from tent labs to something better
- Make a custom aluminum case for the remote
Chain:
- Transport: Shiga MK2
- DAC: Soekris DAM1021
- Pre: Passlabs Preamp / Naim NAC 152X
- Amp: Passlabs XA30.8 / Symasym Black Beauty / Sony VFet Part 2
Plays absolutely perfect.
Old 1st March 2017, 07:15 AM   #1517
tvicol's Avatar
Impressive work Fabian !
Shiga MKII with Soekris DAM1021 make a fantastic pair. You have a top notch digital source there.
One wire do no make contact on your display. Better solder ribbon cable to avoid contact loose.
Tibi
Vicol Audio
Old 1st March 2017, 07:18 AM   #1518
Thanks tibi, pictures are a little bit older. Most stuff is soldered and double checked. One big "problem" of the 1U case and my transport / main pcb placement was, that on later tracks, the FPC cables bend was so big and the cable could not make that bend to the top (as the height of the case is only 40mm), that later tracks could not be read. Had to use a shorter cable (127mm) and use a more flexible series.
Old 1st March 2017, 07:25 AM   #1519
Some more pictures of the aluminum block and the DAM build....
File Type: jpeg WhatsApp Image 2016-08-10 at 22.49.02.jpeg (345.5 KB, 112 views)
File Type: jpeg WhatsApp Image 2016-08-10 at 22.49.08 (1).jpeg (343.8 KB, 107 views)
File Type: jpeg WhatsApp Image 2016-08-10 at 22.49.08.jpeg (372.8 KB, 112 views)
Old 1st March 2017, 05:55 PM   #1520
Hiya Fabian
Very impressive. You will be feeling like the cat who has got the cream I am sure.
Can you please write more about your "custom springs"?
I was going to try using springs from suspension in Radio controlled car/4wd but hard to find good size.
Clayton
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
