Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 21st April 2016, 03:17 PM   #1381
69mach1 is offline 69mach1  Netherlands
Default CAD
Originally Posted by tvicol View Post
John,
Which CAD are you using ?
So far we made our projects in FreeCAD and Inkscape and we are looking for something feature rich and easier to use.
Tibi
Hmmm I might be a little late with the answer i suppose, The cad i use is solidworks and then i render it via Keyshot 5.
I have been far to busy to do anything with the Shiga, it is still sitting on the audiophile piece of mdf.
I do have a lot of boxes with parts and about 30kg of raw aluminium stock.
I am glad to see you made a very goodlooking chassis for the shiga, and also a nice remote housing.
regards,
John
Old 21st April 2016, 05:00 PM   #1382
tvicol is offline tvicol  Romania
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Thank you John, for your replay.
We managed to stay away from commercial software. Therefore, at right time, some Quantum files will be shared with community.
Looking forward to see your final Shiga unit.
Tibi
Vicol Audio
Old 22nd April 2016, 04:24 PM   #1383
Guarnera is offline Guarnera  United States
Default Quantum dimensions?
Hello Tibi,
Lots of great pictures of Quantum. Can't wait! But I don't see the dimensions posted anywhere. What's the size? Height from table top to highest spot on top? Width, and length? Thank you.
Old 23rd April 2016, 12:07 PM   #1384
nbivol is offline nbivol  Turkey
Default shiga ''le monstre''
Hi folks,
Here you can see fully D-Reflektor-ized Shiga MKII .
It took some time before I could gather all the pieces together , but it was worth . I did not encounter any difficulty , everything I needed can be found in this thread . It is powered by 4 D-Ref for V1-V2-V3-V4 and 2 Ales ''mravlca'' TPS7A4700 low noise LDO regulators for J6 and Burson clock .
2 r-core (9V 30VA)and one toroidal (12V 50VA) transformers.
There is alot of cool staffs used to build D-Refs like Mundorfs caps , Caddock MP930 resistors , Vishay S102 res , Black Gates .
I also changed some capacitors on Shiga board to Black Gates .
The improvement is ... you have music in your room , alot of transparency and spaciousness , very fluid and detailed . Just perfect .Even my wife listening from the kitchen did noted that she hear every detail as if standing in front speakers .
So ,have to say many thanks to Tibi ,thanks for the help and for making this project come true.
Old 23rd April 2016, 12:22 PM   #1385
tvicol's Avatar
Very impressive work for a musician !
Congratulations Nicolae !
Tibi
Vicol Audio
Old 23rd April 2016, 12:24 PM   #1386
taccodude is offline taccodude  Germany
Hi nbivol, looks nice.Did You built a Version without all the extra Parts before,to see what`s worth an upgrade ?
Regards DT
Old 23rd April 2016, 01:29 PM   #1387
Tibi
Thank you Tibi.
Hi TD ,all changes were made from the basic kit offered by Tibi and made one by one , after careful listening and burnin period go on to another mod .
You can see previous version of my Shiga some pages before and this is same board .
As about the parts used are parts of my favorites that I preferred during DIY audio.
Nicolae
Old 24th April 2016, 06:41 AM   #1388
tvicol's Avatar
Originally Posted by Guarnera View Post
Hello Tibi,
Attached are Quantum dimensions.
Tibi
File Type: png Quantum dimensions_-_691642605426966534.png (68.3 KB, 193 views)
Vicol Audio
Old 24th April 2016, 07:19 AM   #1389
nbivol. can You say which Mod made the biggest Improvements ?Did You try the Regulators from Tibi ,against the other Regs ?
Regards DT
Old 24th April 2016, 05:35 PM   #1390
TD,
Since the EZ shiga times I understood that the most important mod is to separate power supply for each line . Because of this I have not even tried mini regulators from Tibi . From this point of view Tibi created the perfect board, giving the possibility of powering all components separately. And that's the answer,if you want, the biggest improvement is given by separate power supplies with own transformers ,rectifiers,filtering capacitors etc.
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
