Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 1st October 2015, 02:21 PM   #1291
comickitkit is offline comickitkit  Macao
Thanks Tibi, finally I combined Shiga and Neutron Star clock fixed on one board. And that is the 1st to listne it with Nordost Odin SPDIF cord (DIY). The body is full and details.
Current system now is
1 Shiga Transport with external clock.
2 Soekris Dam1021 R2R DAC
3 5687/80 tube amp (0.7w output)
4. Coral Beta 8 fullrange speaker
Sound very good, very enjoy
Thanks Tibi help again
Old 1st October 2015, 02:32 PM   #1292
tvicol is offline tvicol  Romania
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Glad you like it !
I enjoy Shiga MKII + Soekris DAC in my system too. Killer combination !!!
Tibi
Vicol Audio
Old 6th October 2015, 03:14 PM   #1293
69mach1 is offline 69mach1  Netherlands
Originally Posted by Turbon View Post
Anyone using Salas Reflektor-D for their shigas? What mods did you implement? One for the lot or several for different voltages?
Hi Turbon,
I am going to use the reflektor's in my build, i was waiting for the groupbuy.
In the build thread there are some mods recommended, i am also still investigating.
http://www.diyaudio.com/forums/power...-d-builds.html
It starts getting interesting from page 25 and up ;-)
I am going to use 4 5V reflektors and for the 8V i am going to use a teddy pardo ruperreg.
Transformer, bridge, big filter capacitor in external box, regulators in cd box.
regards,
John.
Old 6th October 2015, 03:18 PM   #1294
Isn't that neutron star a thing of beauty!!!
how is the sound of the soekris dac different from the buffalo? and is it a balanced design?
i am still using a buffalo 32s, its maybe time for an upgrade.
John
Old 6th October 2015, 03:51 PM   #1295
Turbon is offline Turbon  Sweden
Turbon's Avatar
I am so happy to see builds on wooden boards - still haven't been able to build a good box for my shiga mk2 - so every picture relieves me from having bad feelings over my lazyiness
Old 11th October 2015, 11:40 AM   #1296
Hi Tibi,
I got the problem on CD reading.
After listening music a hour, I changed a disc (after then I changed several discs), the Shiga started to be enable to read disc.
I press the button for Cd door, it started to read, but the display flashed `--` and then shows `00`
I have recorded the lens movement on following YouTube link:
https://youtu.be/gH6xASdzDCg
Normally what is that problem caurse
Old 11th October 2015, 11:48 AM   #1297
tvicol's Avatar
This is a ribbon cable problem. Please check your ribbon cable to be properly inserted and use the contact spray I recommended in this thread. Also several disconnect connect may damage ribbon cable.
Tibi
Vicol Audio
Old 11th October 2015, 12:29 PM   #1298
tvicol's Avatar
When I say ribbon cable I refer to flex cable between optic and main unit. This may generate a lot of trouble if not proper inserted, or was damaged due too many connect/disconnect.
Tibi
Vicol Audio
Old 11th October 2015, 05:01 PM   #1299
Fabian85 is offline Fabian85  Germany
Making latest improvements before Shiga becomes rested in its case. For clarification with the SPDIF Resistors, to buy the correct Z-Foil ones
R48 = 300R
R49 = 100R
Righty right?
Cheers
Fabian
Old 11th October 2015, 06:22 PM   #1300
tvicol's Avatar
R48 = 300R
R49 = 100R
Righty right?
Cheers
Fabian
Right !
Tibi
Vicol Audio
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
