Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 10th June 2015, 08:39 AM   #1191
Cloontje is offline Cloontje  Netherlands
Default Progressssss
Xerxes has been busy.
Old 10th June 2015, 08:41 AM   #1192
tvicol is offline tvicol  Romania
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Speed is adjusted trough a long feedback which take care of incoming data rate and other factors. LA6541 will try to keep up, but it has some limitations. The best way is to use a different motor with higher speed at same voltage. Some current buffers may be needed.
What you want to do is a long process who require lot of testing and measurements.
Sorry, no simple answer here.
Tibi
Vicol Audio
Old 10th June 2015, 10:15 AM   #1193
danzup is offline danzup  Romania
danzup's Avatar
Default Case finished
I want to share the finish of the case I was starting to build on begining of this thread.
There are not better tube than 6P3S and 6N2P for my ears !
Old 10th June 2015, 02:59 PM   #1194
69mach1 is offline 69mach1  Netherlands
Nice one xerxes, but.... are you watching a cooking show while you work on the case?.
regards,
John
Old 10th June 2015, 03:03 PM   #1195
That looks stunning Danzup, love the combination shiny stainless, shiney black and natural wood, nice contrasts.
regards,
John.
Old 10th June 2015, 03:17 PM   #1196
Tibi
Hi Tibi,
No worries, i'll just try and see if it works.
the direkt drive motor only runs at 500 rpm, i just hope there will be some wiggle room.
If not i'll ajust the ratio's back to original, or look for a different motor.
I'll put a heatsink on the chip just to make shure it doesn't get to hot.
Thanks for looking at it.
regards,
John.
Old 10th June 2015, 03:57 PM   #1197
A little bit of progress.
I build two Salas refelktorD's for the shiga.
I bought them for my dac, but.. ahh well why not in the shiga.
They are obviously very easy to build, if i can do it.....
I only had to flip the wires because i put the mosfets on the other side of the board.
Still waiting for the R core transformers i ordered from selectronics france, then i can test the different caps i ordered for the raw power.
John.
Old 10th June 2015, 07:08 PM   #1198
danzup's Avatar
Nice , very nice , hard aluminium !
How will you finish the case ?
Brushing or shining ?
Old 10th June 2015, 07:11 PM   #1199
danzup's Avatar
regards,
John.
Thanks , that was the whole idea a lot of contrast ...
Like Shiga : the little Cinderella that in the end is the Queen after all ...
Do not we live in fairy-tails ?
Old 11th June 2015, 03:16 AM   #1200
None
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
