| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
The DAC kit made bu "Keces.com"......
Can anyone tell me how I can purchse this? Is just the PCB and chip available? Also... Is the PCM2902 pin for pin compatible with the PCM2702? What are the differences between these chips? THANKS! |
#2 |
http://focus.ti.com/docs/prod/folder...t/pcm2902.html
http://focus.ti.com/docs/prod/folder...t/pcm2702.html You may do the comparison on your own. |
#3 |
#4 |
The difference between those chip can be made simple by one feature... SpctAct USB interface.
This is a rather interesting (and good) interface designed by BurrBrown Japan. Simply speaking, it allows very precise tracking of USB host clock (which itself is not very accurate) and greatly improves the sound quality. (I once saw the designer's note on the development of this chip... it is amazing the hoops he jumped through to get this chip working like it is.) This feature combined with the other specs of this chip, makes it heads and shoulders above other chip with similar functions. Even other BB/Ti chips, including PCM 290x and PCM270x (excluding 2702 of course) series. The Ti's datasheets made that quite clear. :P |
#5 |
Ah, forgot to introduce myself. I'm the English language support staff of KECES. My e-mail (for now) is from my day job, but if you want to ask anything that's not quite apporiate here, you are free to e-mail me directly. Otherwise, post here and I'll try to check back as often as possible.
Thanks. |
#6 | |
"SpAct™ (Sampling Period Adaptive Controlled Tracking) system recovers a stable, low-jitter clock for internal PLL and DAC operation from the USB interface audio data." From Ti Product info web page. This is one feature that I wouldn't do without with USB DAC products. Chips with it does not automatically become great DAC, but an USB DAC chip is cripped without it.
#7 | |
Korping I have just looked at your site with Chinese Language support and all I got was neither English or Chinese. What is going on? |
#8 | |
Well, Koping is not well versed with English... so I'm here to respond questions in English... Call me Maniac or David... whichever you prefer... :P With Chinese support, you need to install the proper support in your system before you can see it. Otherwise all you will see is a bunch of garbled ASCII code... You need Traditional Chinese support to be exact. Simpilified Chinese uses different encoding, and thus cannot be used to view the page. |
#9 |
[With Chinese support, you need to install the proper support in your system before you can see it. Otherwise all you will see is a bunch of garbled ASCII code... You need Traditional Chinese support to be exact. Simpilified Chinese uses different encoding, and thus cannot be used to view the page. [/B][/QUOTE]
------------------------------------------------------------- I have traditional Chinese support; in fact I am Chinese and there are no problems with other TW sites. What to do next? |
#10 |
diyAudio Moderator Emeritus
PC (Internet Explorer):
View- Encoding- Chinese Traditional Mac (Safari): View- Encoding- Traditional Chinese It then looks like Chinese to me
| KECES da-151 or hifidiy pcm1794 usb dac? | cougarz | Digital Source | 0 | 4th January 2009 02:27 PM |
| My USB audio DAC (PCM2702) | veteran | Digital Source | 8 | 17th August 2006 08:33 PM |
| Is anybody can help me with my PCM2702 | burderly | Digital Source | 4 | 5th August 2006 03:51 PM |
| Pcm2702 Usb-dac | 00940 | Digital Source | 47 | 24th January 2005 04:36 PM |
| Pcm2702 Usb Dac | sugano | Digital Source | 9 | 27th May 2003 06:37 AM |
| Page generated in 0.12333 seconds (80.21% PHP - 19.79% MySQL) with 11 queries |
