| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi There!
I've build Fedde's NONOZ-II DAC using the CS8412/TDA1543-combination and my own PCB-layout. Is there a way to put a "signal-lock"-LED on the CS8412 so I can see if a signal is present on the input of the receiver? /U. |
#2 |
Pin 28 of the 8412 goes 'low' with valid signal lock, if that's what you need to know.
#3 |
Pin 25, the ERF flag goes high when out of lock. I use a red led to gnd so that it goes out when the signal is locked. Connecting an led between V+ and pin 25 will do the opposite.
#4 | |
/U. |
#5 | |
Electrons are yellow and more is better!
http://home.swipnet.se/~w-50719/hifi...ma_sida_1.html
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
Pin 25 not 28. See the datasheet. http://www.geocities.com/rjm003.geo/...pdf/cs8411.pdf
#7 |
Nisbeth, I think you've got it... If you hard tie the anode to a +5, a 200 - 1000 ohm ought to do fine, depending on the LED. You can do the reverse with pin 25, BUT I'd rather 'ground' an LED to fire it as opposed to actually using the chips internals to drive it high. That's just me
#8 |
Thanks Scott, I'll try it
/U. |
| "A standard CD player outputs signal at 24V" | wwenze | Digital Source | 16 | 13th July 2009 04:50 PM |
| How do you connect a PLL "Lock" LED to the CS8416? | G | Digital Line Level | 1 | 3rd March 2009 06:47 AM |
| "Super-Pair" I/V for TDA1543 | rbroer | Digital Source | 159 | 19th November 2004 01:11 AM |
| Page generated in 0.09078 seconds (76.25% PHP - 23.75% MySQL) with 10 queries |
