Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th January 2004, 10:54 PM   #1
Default Opinion on Cs43122 in this schematic
I have seen using a Cs43122 in a Pre/dec. Rotel :
After this DAC a TL072C, then the digital volume control and an output stage with a OPA2604 .
The strumental result: good until 16bit/44Khz, average on 24bit/48Khz. and up with spectrum noise floor clean but no lower that -130dB.
Integral resolution no better than 15.6 bit, S/N weighted 98dB ( the highest measured ) on the multichannel input ( also buffered with TL072C ).
Opinion ?
Can the TL072C be the reason of this result ?
Thanks and regards
Marco
Old 5th January 2004, 08:21 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
TL072 is sonic poison. Replace them all for something decent like OPA2604 for better sound. Don't know if the measurements become better ( some will ) but it *will* sound better.
I suspect the digital volumecontrol has influence on the results ....
It's only audio
Old 5th January 2004, 08:56 PM   #3
Thanks for the answer.
The volume control is not done with the usual Cs3310 or PGA2311 but with two Toshiba Tc9482 .
The strange thing is that Rotel do magnify the use of the CS43122 and the OPA2604 and then between these good chips put several TL072C and some 5532.
I cannot understand this in a 3500 $ pre/decoder ...........
Marco
Old 5th January 2004, 09:11 PM   #4
jean-paul's Avatar
I can. It saves some
It's only audio
Old 7th January 2004, 11:24 PM   #5
Default TL072!!!
TL072s were state of the art for 1975. I cannot understand anyone passing audio through them now. Replace them with something decent. The OP275 is a good choice. Even the LM833.
Dan Fraser
My opinion on Audio Note M10 schematic - Japan version tim845 Tubes / Valves 0 11th May 2008 05:09 PM
need help, about CS43122 cubezone Digital Source 0 7th May 2007 01:41 PM
What is your opinion on this schematic for OPA-541 100db Chip Amps 17 17th March 2006 02:52 PM
Schematic opinion needed (guitar amp) Trout Tubes / Valves 8 2nd March 2006 02:35 AM
el34 se schematic opinion trancy Tubes / Valves 3 21st April 2004 03:52 PM
Page generated in 0.07705 seconds (71.97% PHP - 28.03% MySQL) with 10 queries
