Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Philips CDM-1
Philips CDM-1
Old 3rd June 2011, 01:41 PM   #61
lcsaszar is online now lcsaszar  Hungary
I read somewhere that the CDM-1 tracking uses 660 Hz modulation, but I can't remember the details. Is perhaps that "oscillation" you hear?
Old 3rd June 2011, 03:06 PM   #62
dulci2se is offline dulci2se
It is this oscillation which is audible, I think it is 600Hz or 650Hz which the TDA 5709 uses. It is not caused by the chip being faulty though....it is wear in the motor spindle I think. If the CD clamp was made more rigid with regard to centering then this would cure the problem I think, however it's difficult to alter this being plastic.
The TDA5709 chip can be adjusted by using different capacitors and resistors, however the data sheets which I have seen do not explain the exact workings of this, so again, this is difficult to experiment with and you need quite tight tolerance capacitors and resistors....I think the damping method may work, probably adding a damping ring to the CD clamp....just trying to find a suitable piece of rubber or felt to use......will post my results....
Old 5th June 2011, 02:34 PM   #63
650Hz is the frequency used by the TDA5709. I have not managed to add any damping it's just too awkward to do. I am going to fit a miniature bearing (MR63ZZ) to the motor shaft which will not allow any play as I shall use a bearing bond to fix the shaft to this if needed. These bearings are used in model helicopters and are quite cheap to buy off ebay and similar and can be run up to several thousand RPM which is well above what is needed (520RPM)......hopefully this will work....or else it's the recycling skip for this player...shame.
Old 6th June 2011, 08:25 AM   #64
poynton is offline poynton  United Kingdom
poynton's Avatar
Oh, please !! Not the skip !!
Let me have it !!
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 6th June 2011, 03:58 PM   #65
JonHarrison is offline JonHarrison  United Kingdom
Or me
Old 7th December 2012, 12:40 PM   #66
Resurrecting this old thread:
There is no Focus Bias adjustment in the Philips CDM-1, unlike at Sony mechanisms (and no Tracking Offset, Tracking Gain either). The only adjustments are Laser Output, Focus Offset, and Focus Gain. Also the RF preamplifier is a thick film unit on a ceramic substrate. Does it mean there is no way to adjust the eye pattern? Perhaps the mech is so stable there is no need to adjust anything.
I am asking it because I want to make my Marantz CD94 be able to play CD-R reliably.
Old 3rd December 2017, 01:05 PM   #67
ClassA is offline ClassA  Taiwan
Hi Eric,
My Philips CD960 has some problems. When I turn the power on, the disc turns reversely then stop and the laser light is very weak. What parts should I check? THANKS!!
Philips CDM-1Hide this!Advertise here!
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips CD 960 @lf Digital Source 13 16th October 2006 06:08 PM
Philips cd 931/00 jimraft Parts 1 12th November 2005 05:19 PM
