Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Philips CDM-1
Philips CDM-1
Old 2nd September 2008, 06:39 PM   #51
NoBit is offline NoBit  Italy
Send a message via MSN to NoBit
hello garwood
Do you need help?
Let me know, maybe I can help you
Old 4th September 2008, 07:56 AM   #52
Default cdm1
Hello
I still continue to try to fix the problem;
The new scenario:
If the cd has more than 14 tracks and the last is totally played, after powering off the unit and repowered (with the cd still inside) the unit fails to read TOC.
The second time (repowered again) the TOC is readed correctly.
If I put the unit in vertical position (the front panel down) this error doesn't appears.
I tryed to modify the turntable height, the focus offset, the focus bandwidth and finally the laser power but nothing solve the problem.
Could be a not totally correct swing arm alignment?
Thanks a lot
ciao ciao
Eugenio
Old 4th September 2008, 08:14 AM   #53
poynton is offline poynton  United Kingdom
poynton's Avatar
From your description, I would guess the swing arm is not entirely free to return properly.
It may be the bearing or the cable.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 4th September 2008, 10:42 AM   #54
for the bearing I adjusted the "pressure" as described in one of the first post in this topic, now it moves much more better opposing a very few force.
The cable... I have deeply cecked the two flat cables and they seems ok
This evening I'll try to realign the swing arm manually; maybe the arm in vertical position moves just a little to realign itself respect to the turntable... I tryed to adjust the electronic part but none is changed, in some cases the solution was in removing the cd and place again on the turntable.
What do you think?
This is my hobby, I love it because helps my brain to stay up
thanks a lot
ciao ciao
Eugenio
Old 5th September 2008, 10:51 PM   #55
Default cdm1
Test still continue.
I replaced the entire transport with another cdm1 and the problem still continue, less than the other (due to a different pots setting) but it is present.
Observing the unit i think that the problem is generated by the focus detection; while the arm is turning to the center of the disc (parking position) the turntable start, it seem that the focus is found during the arm movement to the center, so because the TOC isn't found the disc rotation speed increase and the error message is simply the result (when the lens is under the TOC section the disc speed is too high).
Now I'm trying to decrease the focus so the disc starts only when the arm is in "parking" position.
ciao ciao
Eugenio
Old 12th January 2011, 10:40 PM   #56
AttilaSVK is offline AttilaSVK  Slovakia
Hi all!
I'd like to resurrect this thread with a question: what's wrong with my Philips CD204?
The symptoms are:
1) The disk often skips forward a few seconds, but not always, even on the cleanest original CDs... For example, I'm now listening to a CD for quite a long time, without any skipping.
2) While fast forwarding the disc (by holding the search --->> button), often it has problems to reach the end of the disc. Sometimes the forwarding slows down, and sometimes it even starts to skip backwards. If the forwarding is OK, it won't skip as described in point no. 1.
3) Sometimes the mechanism starts to "scream" and it won't read discs. It happened to me a few times that this occured while playing the disc. The playback stopped, and the player displayed only -- on it's display.
To hear the "screaming" of the mechanism, click HERE
Also I'm wondering if it's possible to connect a CDM-1 instead of a CDM-2/29 or CDM-4/19. It would be nice to have a CDM-1 player with the SAA72xx chips and TDA1541 DAC, since I can't afford a CD304 mkII.
Old 10th February 2011, 05:02 PM   #57
Hello!
Since I didn't get any reply, I decided to change all caps on the power supply board, and also the 33uF ones under the transport, next to the 2 connectors which go to the swing arm. Unfortunately it did not solve the problem.
I think the problem is with the tracking / swing arm control, as the ocassional screaming (see previous post, point no. 3.) is coming from the swing arm.
Thanks in advance for the replies.
Old 11th February 2011, 02:10 PM   #58
Bump with some news...
Well, yesterday the player was behaving really well, I listened to 4 or 5 CDs in a row, without a skip. I just came home, wanted to listen some music, but it skips again. Sometimes only a few seconds, but somtimes even 20-25 seconds.
Also I observed that the sound of the tracking mechanism gets louder and louder before the skip, and after it's normal again.
Apart from that, it can't play a whole track without screaming and refusing to read. With the same track on the same CD (which played without problems yesterday) it failed after 15 seconds, and then after retrying it went for two minutes.
I forgot to mention that the swing arm can move freely...
Old 25th May 2011, 08:03 PM   #59
dulci2se is offline dulci2se
Red face Screaming / sqeaking CDM2/10
I am having a similar problem with a Philips CD160.....CDM2/10 mechanism. This only normally occurs on track one. If I skip to the next track the scream/ squeal will stop and the CD will play normally.
I have replaced most of the electrolytic caps on the CDM mechanism and in the power supply, along with several diodes and other plastic capacitors. I have also dismantled the motor spindle and reset the disc height. I am pretty sure that the motor spindle is not the cause.....it seems to be down to the focus drive / laser electronics, but I cannot pinpoint the problem and don't have an oscilloscope. Voltages appear to be OK to the various sections. I have also soldered most joints that look suspect. The machine does not get any better, which is a shame as it sounds good when playing.....There are some feedback components on the L272M IC (0.39uf cap and 43k resistor) which were discoloured and I have changed these, but still not working......any help appreciated....
Old 2nd June 2011, 06:45 PM   #60
After further investigation the noise appears to be caused by a very slight oscillation in the turntable motor assembly. I am going to try damping this with some felt under the CD or maybe on the clamp. This obviously needs to be thin to keep the CD height correct or within tolerance. I have already had the motor assembly apart, but can't seem to improve it with light oil or grease and I have also tried to close the tolerance on the bearing without any luck.....maybe the felt will help. The mechanism must be very sensitive to this slight oscillation.....shows how good the tracking is on this mech......
Philips CDM-1Hide this!Advertise here!
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips CD 960 @lf Digital Source 13 16th October 2006 06:08 PM
Philips cd 931/00 jimraft Parts 1 12th November 2005 05:19 PM
