Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd January 2004, 06:50 PM   #1
Smile Double CD player from CDROMS
I assume that this forum is the correct place for discussing homebrew CD players using a microcontroller/CDROM drive combination.
I have done a webpage about a project aimed at adding a little more features to such a setup:
http://www.astro.uu.se/~marcus/private/mcd1.html
Note that this is still only a partial project description, since it is not complete. However, it may be of interest to someone. I am particularly curious to see if someone else has built something similar.
Best wishes,
Marcus
Old 2nd January 2004, 07:03 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Hi Marcus,
Your web description is impressive
I'm not into disco, but I have been following this thread:
DIY CD drive based on a computer CDROM which may interest you.
That is, of course, if you're not ahead of the game already
Old 3rd January 2004, 01:46 AM   #3
MCLL is offline MCLL  Hong Kong
MCLL's Avatar
My Previous DIY DAC
http://hk.geocities.com/leo8597/
But Chinese Only...
Using Web Translate...
http://babelfish.altavista.com/
Old 4th January 2004, 02:21 PM   #4
Thanks for the links!
In the thread with number 17910 I see a couple of people
mentioning a point that I'm wondering about in particular -
Is there some convenient way of altering the
pitch of audio playback on a CDROM drive?
I did not see any responses to this in the thread.
I have seen some hint in the IDE CDROM
specification that the number of audio frames per second may be
an adjustable parameter, but on my Samsung drives this value
was masked as read-only (E version, did not check AE version).
An interesting experiment would be to inject a signal from a
frequency synthesizer in place of the 33.8 MHz master
oscillator in the drive. However, that would probably not be
more than just an experiment.
If, on the other hand, the drive would still operate properly
at + or - 10% clock rate, it could be an interesting continuation
of the project.
Marcus
Old 4th January 2004, 09:44 PM   #5
When injecting clock in a NEC cd-rom drive I managed to hear sound at 1/2 speed, I think. Maybe if you install a DDS it will work fine.
Is this the best Double-Din dvd player with touchscreen out there? kcmoguy26 Car Audio 2 16th December 2008 01:05 AM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 09:12 PM
Double rail PSU, double ground rail connexion ? youyoung21147 Chip Amps 5 6th November 2005 06:12 PM
Stand Alone CD Player vs. DVD Combo-Player Tom D Digital Source 0 2nd January 2003 05:08 PM
Computer CDROMs fmak Digital Source 2 1st January 2003 06:46 PM
Page generated in 0.07542 seconds (79.11% PHP - 20.89% MySQL) with 10 queries
