Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Audio Measurement ADC input stage
Old 28th February 2002, 04:27 AM   #1
tiroth is offline tiroth  United States
Default Audio Measurement ADC input stage
I'm considering building an ADC or using a stock sound card as an input in order to take advantage of computer-based measurement tools. How have others solved the input protection problem?
(While "always use an attenuator" is an option, I would prefer to have both a "protected" input as well as a bare "hi quality" one)
What about the circuit below, shamelessly adapted from the Bitscope plans? The bandwidth of interest would be 10-100kHz, and 103dB S/N with very low distortion would be considered minimal. I am not sure that the 82pF cap serves any purpose at these frequqncies. I've seen designs with zeners but I would think these to be far too noisy. Are there other alternatives? I am afraid to go active in what will be my measurement set.
Old 19th March 2002, 04:58 PM   #2
Kay is offline Kay  Germany
Default Input Stage
Use Led's instead of 1N4148.
regards
Kay
best regards
Kay
Old 19th March 2002, 05:56 PM   #3
Lower noise?
Old 19th March 2002, 07:47 PM   #4
Default LED
>lower noise
Yes, you see LED's in current sources for improvement.
And you get lower distortions, but it's dependend for the level you can accept or you need at your input.
regards
Kay
best regards
Kay
Old 20th March 2002, 07:42 AM   #5
kiwi_abroad is offline kiwi_abroad  New Zealand
kiwi_abroad's Avatar
The reason LED's are used in current sources is due to their voltage drop of around 2.0 - 2.2v (depending on colour), not 0.6v for a diode (plus it looks cool having a led glowing away on the PCB).
Does anyone have any definitive proof of the noise contribution of LED's over normal doides?
Old 20th March 2002, 08:03 AM   #6
sonnya is offline sonnya  Denmark
sonnya's Avatar
I have not been able to find any proof of LED versus normal diodes (Not Zeners), but would like to hear if any papers exists on this matter.
I think using LED as OVP is a bad idear. They are not as fast as ~1n4148 or schottky (only .2V drop) or fast recovery diodes.
I would go for the 1n4148 because of the lower capacitance across it.
For the cap 82pF across 10k: Depending on the size of the inputcapacitance of your ADC i would think it only has a little impact above 50 - 100KHz. Try run without first.
Sonny
Audio Measurement ADC input stageHide this!Advertise here!
Adding a third input to a differential input stage? maudio Solid State 15 11th October 2006 02:16 AM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
DVD-Audio and SACD Media for measurement hwb Digital Source 0 22nd February 2005 06:04 PM
Audio Amplifier Input Stage Randy Knutson Solid State 3 20th June 2004 08:33 PM
