Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th February 2014, 10:32 AM   #1
Default PCM1704 channel splitting and propagation delay
Hi all,
After lurking a lot and being overwhelmed by the strong knoledge of the users of this forum, I'm going to ask you a question
I am designing my first DAC and I have a 24 bit Right-Justified stream as PCM1704 likes to see at its input. Data come from an AD1896 through an insulator from digital to analog section.
Now I am going to split the DOL and DOR with a quite rought way using a Schmitt-Trigger (does it make sense to use a S-T?) inverter. Please refer to my schematic.
My big question is: due to the fact that the inverter is only on the frame clock I am going to add a propagation delay only on this line. Assuming to use Potato inverters we are speaking about 1.8nS in 15pF. Only on one channel.
Now I see that Potato also produce quite simple things like "delay elements": not inverting inverters LMAO.
http://www.potatosemi.com/potatosemi...t/PO74G34A.pdf
Do you think it could be useful to place that delay elements thingy on all the lines to DACs in order to keep all the signals time-aligned?
Many thanks guys and sorry for my bad English!
Old 14th February 2014, 10:02 AM   #2
Originally Posted by danils View Post
Hi all,
Try Google search;
"pcm 1704 non-os dac"
and
"nos pcm1704 dac"
Nick
Multiple parrallel PCM1704 per channel new2hifi Digital Line Level 18 4th December 2013 08:57 PM
PCM1704 Help needed with higher dc offset from one channel georgehifi Digital Source 12 13th December 2012 10:08 AM
Delay line for front channel jayadev Analog Line Level 19 8th December 2011 08:49 PM
SM5847 propagation delay apolon34 Digital Source 14 20th April 2008 01:14 PM
UcD - correlation between phase lead network and propagation delay Cro maniac Class D 2 12th April 2008 06:35 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
