"Super-Pair" I/V for TDA1543 "Super-Pair" I/V for TDA1543 - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th December 2003, 04:37 PM   #1
rbroer is offline rbroer  Netherlands
rbroer's Avatar
Default "Super-Pair" I/V for TDA1543
Here's the latest incarnation of the folded cascode, common base I/V converter.
Just finished it, and it's up and running
The TDA1543 part of this pcb,
with synchronous reclocking of I2S signals,
Tent XO and the digital supplies can be found here,
http://www.diyaudio.com/forums/showt...044&highlight=
It's basically unaltered, using VHC logic for synchronous reclocking, several 220u/10V Sanyo Oscon's for bypassing, mixed with 805 SMD combo's of 100n & 10n per Pete Goudreau
Again I settled on 1000u/10V Rubycon ZL with 220u/10V Sanyo Oscon for the TDA1543 supply.
Each chip gets its' own very tiny and very low noise REG101-5 regulator, 805 smd 100n+10n for the BYPASS pin.
I left the DC servo out this time, since my amplifier has one of its own already. Peter Daniel reported some negative influence, even though my simulator THD measurements indicate no ill-effect.
The jfet cascode on the 2nd current sink does improve things, again the THD measurement in the simulator tell me it shouldn't make a difference
Implementing the super-pair brought a small improvement, now the simulator promissed a large improvement
Important lesson learned: DO NOT TRUST SIMULATORS, sorry Jocko, needed to find out for myself...
Riv is a mix of Riken (1.5k), Tantalum (10k) and DALE RN65C (40.2k), Civ is a Philips 1.0n KP
Q2N is 2SC2547E
Q2P is 2SA1085E
all other bjt's are BC549C and BC557B
100u/25V and 470u/25V are Rubycon ZL series
Resistors are small Beyslag series MRS16T
I'll probably leave it this way now, don't have may ideas how to improve it.
Tried the CFP, didn't like it (oscillated at first)
Happy DIY,
Rudolf Broertjes
Old 30th December 2003, 04:41 PM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
"Super-Pair" I/V for TDA1543 Send a message via AIM to Peter Daniel
So how much better is it, comparing to a previous version? Mostly, is it worth upgrading?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th December 2003, 04:48 PM   #3
rbroer's Avatar
Here it is:
Rudolf Broertjes
Old 30th December 2003, 05:13 PM   #4
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Hi Rudolf, is D3 a LED ? I don't think it is but what diode do you use there ?
It's only audio. Member of the non modular PCB design committee
Old 30th December 2003, 06:34 PM   #5
Bricolo is offline Bricolo  France
Bricolo's Avatar
What's the difference between a super pair and a CFP?
Old 30th December 2003, 07:32 PM   #6
rbroer's Avatar
Currently I like it a lot, doesn't mean zip to you, I know
Bit hard to tell, since only yesterday I re-installed the jfet cascode on the previous I/V board.
Did you install that jfet on your board btw ?
I'll let you know in a couple of days.
You could use a 4148 diode, but I used a green LED...think like Christmas trees
Rudolf Broertjes
Old 30th December 2003, 08:01 PM   #7
jean-paul's Avatar
Default Why did I ask ?
I only see 4 LED's on the PCB, that's why I ask. In your schematic I see 5 LED's ( 3 green ones and 2 red ones ).
BTW since the servo is omitted maybe it is better to use an output cap + resistor to ground after it ? Could you repeat the adjustment procedure in this thread for those that don't know the Search function ? The Iref resistor for TDA1543 will be 1k2 ?
Did you change your design for TDA5141A like this one as well ?
Many questions but not meant negatively.
Jean-Paul
edit: I checked again and I now see that there are 2 LED's D3 in the schematic ...
Old 30th December 2003, 08:55 PM   #8
Bricolo's Avatar
Old 30th December 2003, 11:38 PM   #9
Pedja is offline Pedja  Serbia
Old 30th December 2003, 11:45 PM   #10
Bricolo's Avatar
Thank you
Where can I learn more about them?
"Super-Pair" I/V for TDA1543Hide this!Advertise here!
Peavey "Super Festival" VTA-400 - upgrading to 400W? pharaohamps Instruments and Amps 11 22nd March 2009 12:25 PM
"super pair" I/V new 12.7V version mikelm Digital Source 7 19th September 2004 09:42 AM
"Signal Lock" Indicator for CS8412/TDA1543 Nisbeth Digital Source 7 5th January 2004 09:02 PM
Audio Crafters Guild "Super Symmetric Power Supply" raincheck Digital Source 16 22nd April 2002 08:06 AM
Copyright ©1999-2017 diyAudio
