Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th December 2003, 05:30 PM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default Splitter for S/PDIF
Can I use this as a splitter for S/PDIF.
The primary is 7 turns, the sec, is 2x5 turns.
This is originaly ment for 1in and 2 out, but I want to use it as
2 in and 1 out. Is this possible?
Old 28th December 2003, 04:28 AM   #2
Banned
Default Yeah.......maybe......
But who knows? Hard to say without knowing its frequency characteristics.
But.....my guess is it will sound like dreck even if it does work.
Here......make a resistive splitter. Will work much better.
Take 3 25R resistors. Make a "Y" with them. Looks like 75 ohms in each direction, and most frequencies. Any terminal can be a "goes into" or a "goes out of". You will lose 6 dB in the process.
Jocko
Old 28th December 2003, 07:12 PM   #3
Giorgio is offline Giorgio  Italy
Ryssen,
it should work, I used the same arrangement in the past and it did, but the impedence will not match the required 75 ohm... so results are not high quality, for sure.
I read that you want to use it as 2 in and 1 out: in many cases an idle cd player goes on outputting a SPDIF regular (but zeroed) stream, so that you normally cannot use such an arrangement without some kind of input selector, unless you are availabble toi switch all the other units off; and in this case you are not sure which is the ipedence shown to the connector by the switched off unit....
The Jocko solution seems at least solve the impedence issues, even though all teh other problems named before are still present, and moreover the output level could be not enough to drive the receiver correctly....
Best solution is a IC input selectore as in
http://www.tnt-audio.com/clinica/tnt1541_e.html
schematic in
http://www.tnt-audio.com/jpeg/mwdac1541rec.jpg
kr
Giorgio
Old 29th December 2003, 11:44 AM   #4
Andypairo's Avatar
Hello Giorgio, nice to have you here!
I'm sure your presence in the forum will be very useful for all of us
BTW nice works with your DACs!
Cheers
Andrea
S/PDIF Questions ak_47_boy Digital Source 0 31st December 2007 01:41 AM
S/PDIF Optical to S/PDIF RCA Replacement jdgonko Digital Source 2 11th February 2007 09:35 PM
S/pdif borges Digital Source 9 5th March 2005 12:22 AM
VGA splitter Rookie Parts 1 17th September 2004 03:54 PM
Page generated in 0.07229 seconds (73.73% PHP - 26.27% MySQL) with 11 queries
