Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
24Bit/96Khz on AD1865 DAC
Old 3rd January 2014, 02:54 PM   #1
Tyimo is offline Tyimo  Hungary
Default 24Bit/96Khz on AD1865 DAC
Hi!
Is it realy possible to play 24Bit/96Khz on AD1865 DACs with CS8414 receiver?
Greets:
Tyimo
Old 3rd January 2014, 02:57 PM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
No - AD1865 is an 18bit DAC.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 3rd January 2014, 03:44 PM   #3
Yes, I Know, but it was adwertised by Audionote. Forexample the Audio Note DAC Kit 1.1.
TNT : Audio Note DAC Kit 1.1 Listening Test
AN encourage the owner to replace the Crystal data receiver with the pin-compatible CS8414, which allows for reception of data up to 96kHz and at 24 bit (sigh) word lengths. Of course, while the DAC will happily convert these data, words will be truncated (rather than dithered) to 18 bit, and the passive filter will still cut above 20kHz unless you are prepared to re-design it.
One more the 2.1:
Audio Note Hungary - DA CONVERTERS - DAC 2.1x
Standard chassis converter, 24Bit/96KHz compatible, AD1865N chip with digital filter free 1xoversampling™ direct from disc™ technology with patented Audio Note™ I/V transformer interface and Audio Note™ digital input transformer, 6DJ8 anode follower no feedback output stage.
Old 3rd January 2014, 10:07 PM   #4
abraxalito's Avatar
So then I don't understand your question. Seems its answered in the first quote you included.
Old 4th January 2014, 09:21 AM   #5
I asked because I just can not believe it.
Old 4th January 2014, 01:58 PM   #6
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
I wouldn't worry about the 18-bit AD1865's inability to convert a full 24-bits. If you already like the sound of the AD1865 with 16-bit CD, then you will gain two additional real bits from 24-bit sources, effectively making such sources 18-bit. Therefore, you could still gain about 12dB of dynamic range improvement over 16-bit sources.
Old 4th January 2014, 03:42 PM   #7
O.K. But the another question is: what would be better with high-res music (24Bit/96Khz) playing
- let the DAC itself to convert the data
- downsampling with a software (SoX, SSRC etc.) to 16Bit/48000Khz
Old 4th January 2014, 11:47 PM   #8
abraxalito's Avatar
Definitely down downgrade a hi-res file to 16bits when you have an 18bit DAC. As for whether to downsample to 48k, I'd suggest listen and see which you prefer.
Old 5th January 2014, 06:35 AM   #9
Yes!
Old 5th January 2014, 08:02 AM   #10
MaciekP is offline MaciekP  Poland
MaciekP's Avatar
audio note dac 2.1x with some modifications sounds much better even on 16/44 than real 24/96 straight from linn sneaky, which i use as a spdif source to AN tube dac.
24/96 through AN dac sounds good also, even if truncated to 18bit
24Bit/96Khz on AD1865 DACHide this!Advertise here!
24bit/96KHz CS4397/CS8416 Lampucera DAC with direct capacitor output - $100 wireswithgain Swap Meet 10 23rd October 2013 08:50 PM
Starting for soldering my DAC 24bit 96kHz PCM 1704 K Agus Widarto Digital Line Level 17 7th October 2013 03:01 PM
A/D 24bit/96khz convertor help sunny Digital Source 1 16th October 2006 12:35 PM
USB to 24bit/96KHz edpgc Digital Source 8 21st November 2004 01:40 PM
a/d converter 24bit 96khz s/pdif recording JBL Digital Source 1 10th January 2003 11:58 PM
