Cambridge Audio Azur 640C CD - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th December 2013, 04:55 AM   #1
Default Cambridge Audio Azur 640C CD
Hello All,
My Cambridge Audio Azur 640C CD out of blue start sliding CD tray back and forth as soon as I load the CD in...
Time to change laser head? I hope not, I have maybe 50hrs tops! on this CD player
Aram
Old 24th December 2013, 07:03 AM   #2
Mooly's Avatar
More likely a problem with any tray in/out microswitches. You will have to look at how it senses tray movement and make sure all the switches are OK. Also make sure the laser pickup is in the normal rest position.
Old 28th December 2013, 06:32 PM   #3
Hello Mooly.
Thanks for reply.
I never realize that to open this CD player I will need a Torx driver, end up looking for specialized store.
So I got the T6 driver, took the cover off...
When I plug the power, I noticed that CD motor start spinning for about 20sec, and it stopped, then laser assembly moved down, and I got "NO Disk" massage on the screen.
Then I open and close tray few times, and it was working with no issues.
I placed the CD then, and it works flawlessly.
Do you possibly know what may cause that?
One of the pictures shows the microswitches, are this the switches that you are talking about or there is more
Aram
Old 28th December 2013, 06:43 PM   #4
Mooly's Avatar
Yes those are the microswitches. There could be more, probably one that signals when the pickup is at the rest position (so it would be near the spindle motor)
This shows how to clean microswitches but be careful if you unsolder them, it doesn't take much heat to melt the plastic. Use a hot iron and solder braid.
Sony CDP790 and KSS240 Restoration Project
Old 29th December 2013, 12:25 AM   #5
Thanks Mooly!
If it happens again, I will know where to look for troubleshooting...
Thanks again
Aram
Cambridge audio Azur C540 CD mod. m0rt4l1ty Digital Source 16 29th August 2013 01:56 PM
FS: Cambridge Azur 640C v1 CD player twest820 Swap Meet 1 15th February 2013 02:21 AM
Cambridge Audio Azur 640C V1 dome406 Digital Source 12 15th December 2012 08:18 AM
Rotel RCD-991 vs. Cambridge Azur 640C v.2 Lyra Digital Source 5 24th May 2008 09:26 AM
Cambridge Azur 640C Heat fault fandfac Digital Source 3 25th March 2008 01:28 AM
Copyright 1999-2017 diyAudio
