Philips CdM-2/10 low HF signal - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd December 2013, 11:40 PM   #1
Default Philips CdM-2/10 low HF signal
Hi all.
I'm currently working on a B&O Beocenter 9000 which has a Philips CDM-2/10. There is a common problem that a capacitor has to be changed to a working one, so i replaced that cap. (worked on another CDM-2/10).
Unfortionaly it didn't work so i replaced a few other caps. None of it worked, there are also no cracked solder joints.
I've used my scope to measure the hf output on the servo board and it's only about 40-50mV. The service manual said i should use 1,5VPP.
Does anybody have a clue or something i should try or test?
This is the board before i changed the caps.
the HF output on 0,5uS.
part of the service manual.
Old 24th December 2013, 01:15 AM   #2
Replace those remaining four light blue axial electrolytic caps before you do anything else. They will be either currently bad or in the process of dying. Use Nichicons if you want to assure long term reliability.
Philips CDM-2/10 Laser Tuning Analoguy Digital Source 6 14th April 2014 02:25 AM
SWAPPING CDM-1 FOR CDM-0 IN PHILIPS CD-101 isitrisky Digital Source 2 1st July 2013 12:32 PM
Sound comparison of Philips CDM.1 and CDM.1-MKII noyan Digital Source 2 2nd October 2010 08:45 PM
Dual HF small signal pentodes ? Arnulf Tubes / Valves 4 26th September 2009 04:05 PM
HF filter inductors for signal path cathode_leak Tubes / Valves 3 12th May 2005 09:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
