Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD Player; Negative dc at ac rails;
Old 9th December 2013, 10:54 AM   #1
starbender is offline starbender
Default CD Player; Negative dc at ac rails;
Hello,
I'm struggling with my old Akai CD-62. After simple cap&opamp replacement at the signal paths, transport stopped responding. Sometimes it reads cd's for few minutes, sound is heavily distorted. After a while it does not respond at all. I checked my replacement parts orientation & compatibility. I also checked solder pads and traces. Couldn't find anything. I removed power supply feed from the main board and checked psu readings. Pin readings are correct, except Pin 7&8. There should be 4v AC voltage, but readings shows 2.4V ac & -15V DC! In the meantime STA341M gets really hot in few minutes. At the schematic STA341M feeds by +/-12V DC, I checked STA341M Pin 1&Pin 5;both reads ~6,5V. Final note; If I connect power supply to main pcb, all dc voltages at the pins goes down.
At first; how is it possible to have -15V dc at S5&S4?
Am I missing something?
I attached PS schematic.
Cheers.
Old 9th December 2013, 11:39 AM   #2
DF96 is offline DF96  England
The circuit diagram appears to say that the centre-tap on the AC winding is attached to a -20V rail via a 6.2V zener. I assume this is a heater supply for the display. I would expect to see something like -14V DC here, so -15V is probably fine.
You need to carefully check your "simple cap&opamp replacement at the signal paths". This sort of change, regarded as an upgrade, is often unnecessary and often leads to problems unless it is done one or two items at a time with careful checks in between.
Old 9th December 2013, 11:53 AM   #3
Mooly's Avatar
As DF96 says, the PSU readings appear fine. You have to accept your problem is a man made issue and so you need to go over all the work you have done previously. Are the opamps correct (not fitted a single for a dual or vice versa). The STA getting hot may or may not be normal, I wouldn't just rely on that as a symptom though.
Old 9th December 2013, 12:34 PM   #4
DF96 & Mooly, thanks for the replies. In stock form it has M5532 opamps. I replaced them with OPA2134 and surrounding ecaps. Both opamps are dual channel. Anyway, I'll dig deeper tonight. Let's hope I didn't destroyed something!
CD Player; Negative dc at ac rails;Hide this!Advertise here!
Need schematic for AC to DC converter (12V AC in to 12-18V DC out) maurycy Power Supplies 6 6th January 2012 08:27 PM
Mesure DC in AC outlets Cant find what is making noise in my AC 30CCX Help!!! !!! Ulisez Power Supplies 13 23rd November 2010 06:42 AM
How to use DC battery instead of AC transformer to modify Tascam Cd 601 power supply? mbl Digital Source 2 20th May 2009 04:28 AM
Combined PFC AC/DC & DC/DC SMPS ChocoHolic Power Supplies 33 22nd December 2005 10:04 PM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 03:48 AM
