Marantz cd upgrade - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th November 2013, 09:21 PM   #1
elgee is offline elgee  United Kingdom
Default Marantz cd upgrade vs modifying
I have a cd6000 ose and a cd52 mk2 se. I am looking to improve the sound quality by either modifying either of my existing players or upgrading to a later model cd6003/4/5 which have had good reviews. Trouble is I don't know which would give me the best hike in SQ for money spent. I've read that the 6000ose is difficult to mod and that the cd63/67 is the best for this and there are certainly a lot of mods published for these.
I seem to have a number of choices but not very much comparative info to go on. If anyone can shed any light on these choices I'd be glad of the input. Although I can't spend a fortune I am keen to get the best sound I can without breaking the bank. Any suggestions most welcome. Thanks.
Old 3rd December 2013, 06:43 AM   #2
Andersonix's Avatar
I don't know those models, but if they have any op amps then swap those for new ones...
Old 3rd December 2013, 05:16 PM   #3
Thank you for the suggestion Andersonix. What do you think I should use as replacements? I'll need to check out the model numbers, but assuming there are op amps in there, are there any particular makes/upgrades that you would recommend?
Old 3rd December 2013, 06:17 PM   #4
Johno is offline Johno  Australia
Johno's Avatar
LG,
there are very handy step by step photos in this thread
Replacing the draw cog and belt on CDM4/19 e.g. CD42/CD52
I have also documented the upgrade I did for my own CD52 on that thread - very very happy with the results
Old 4th December 2013, 03:22 AM   #5
Andersonix's Avatar
LM4562 is nice and cheap and comes in an 8DIP package.
If there's a 7805 type Vreg for the DAC, you could go with a Murata SR7805 for about $10.
How far do you want to go? Looks like Johno is very ambitious with his mods!
Old 4th December 2013, 04:55 AM   #6
Johno's Avatar
The CD52 from the early 90's is now getting quite old. Very much overdue for new electrolytic capacitors, especially in all the power supplies. So there is no point making other changes before you replace the capacitors. All I did was find the largest values in fairly good quality types that would fit on the PCB. Essentially narrow but tall types with 105C temp rating.
Recapping alone made a huge difference to the sound quality.
Using LME49720 (or the LM4562) are my preferred op amps. Recommend you install IC sockets as well, in case you need to swap again.
Using an external temp compensated clock module for the DAC noticeably improves the sound clarity, especially with classical music.
Adding the second power transformer allowed the servo motors to run without voltage droop - increases precision. Also separated the noisy digital stuff from the analogue.
And overall I think the CD52 is the better machine of the 2.
Old 4th December 2013, 05:36 PM   #7
Thank you both for the advice. I've already replaced the tray mechanism of the cd52 to good effect - I'll probably give it to my son as the basis for his hi fi setup. I prefer the sound of the cd6000ose so am erring on the side of working on that one. I confess that my electronics experience doesn't amount to much but I can solder & de-solder reasonably well, so I think I'll start with a few straightforward mods like the ones suggested by Andersonix, then move onto the ones Johno mentions. I need to get inside the 6000 to see how it differs from the cd52 and check out which components it uses. Thanks for the suggestions.
Old 4th December 2013, 11:32 PM   #8
Andersonix's Avatar
I also consider myself handy enough around a soldering iron, but I still accept the risk of 'bricking' anything I take apart! Most of these plasticky things are not meant to be disassembled too often...
Old 5th December 2013, 07:05 PM   #9
Yes I've heard that the Marantz PCB is a bit delicate. Thanks for the warning.
Marantz CD-50 and CD-60, TDA1541, CDM4/19 Mayday Digital Source 624 21st March 2013 10:45 PM
main ps cap upgrade for Marantz cd 67se crippledchicken Digital Source 2 30th June 2012 02:31 PM
Marantz CD-84/CD-74 service manual? bleachershane Digital Source 5 4th March 2012 11:00 AM
Marantz CD 74 Phillips CD 104 players speedmetal Digital Source 6 27th March 2006 02:10 PM
Marantz Cd-4000 / Philips Cd-723 (tda1545) maartentje Digital Line Level 1 10th June 2002 05:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
