Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
ebay:Weiliang Dual X2 AK4399 DAC with LCD
Old 15th March 2014, 10:13 PM   #11
ttan98 is offline ttan98  Australia
Originally Posted by keres View Post
Yes, I also have 4x8200 caps I use it with Udoo + Volumio + xmos ak4399 interface and the combination result is amazing.
Imho, the sound is very good also in the single dac akm version, the dual have a bit more large soundstage, but difference in my opinion is not nigth and day.
Also my single version have the same elnas caps upgrade.
Ciao
Inviato dal mio SM-N9005 utilizzando Tapatalk
By the way what is Udoo and Volumio, directly available off ithe shelf if so, please directly me to the websites that sell them. Thanks
Old 15th March 2014, 11:15 PM   #12
keres is offline keres  Italy
http://volumio.org/
Old 21st March 2014, 08:33 PM   #13
Anyone with more experience....
I want try the ada4637 in this dac.
ADA4637-1BRZ requires special application condition (gain >/= 5)
Is it an opamp electrically compatible with the weiliang dac ak4399?
Old 1st April 2014, 07:26 AM   #14
Sunsun22 is offline Sunsun22  Hong Kong
Sunsun22's Avatar
Default Dual AK4399 DAC
This little DAC beats all my previous DACs - TDA1541, dual TDA1541 (double crown), AD1865, 1794, dual 1794 and Benchmark (first generation) with exception of the AD1865 which; in my opinion, a bit better on vocal (perhaps may due to tube output of this AD1865).
When it arrives, it is a bit misty but I can see it has a good potential to modify. In a few weeks time, it ran through the following upgrades: -
Changing the plastic opamp to TO-99 (LME49710HA). I don't have other opamps on hand and this is the only opamp I tried. The TO-99 has more dynamic.
Changing the regulators to Belleson SPM series 15V. The high extended and the low is trimmed.
Changing all regulators to Dexa and Belleson. In fact, the 7805 is a pre-regulation that it could be left as is but I just have a Dexa 7805 spare. At the same time, I also changed the cap of the opamps to Blackgate 47uF 16V, all 0.1uF to Vishay MKP1837 and rectifiers to BVY27-200. More details, more dynamics and musical.
I have a few HiFi friends visited me after the overall modification and eventually I ended up buying 4 more units for them.
My next step - There is a larger case available for this DAC in the market that I will purchase one and try out tube output.
Old 1st April 2014, 07:34 AM   #15
Sunsun22's Avatar
Default Larger case for AK4399
This is the larger case (full size) available in the market.
Old 1st April 2014, 09:16 PM   #16
NinoSimona is offline NinoSimona  Netherlands
I just received this DAC also and I agree: I think it has great potential and it already sounds very nice 'out of the box', although the first few hours it sounds awfull.
I want to get rid of the opamps and install my own discrete output stage with passive filter. The switched capacitor outputs of the AK4399 alow for a nice and simple output stage.
Thanks Sunsun22 for sharing your findings. Did you also consider to split analog and digital supply to the AK4113? It could improve PLL performance, but I don't know if it works in this case.
Old 2nd April 2014, 12:59 PM   #17
Sunsun22's Avatar
I think this could bring some difference by spliting analog and digital supply for AK4113 but I don't have another Dexa 3.3 on hand. I will try to modify a 5V to 3.3V when I have time. In the meantime, I would like to try discrete opamp replacement from New Class D for this dual AK4399 too. Does anyone tried this discrete opamp replacement or similar ones from Burson?
Old 3rd April 2014, 06:02 PM   #18
papparazzi is offline papparazzi  Finland
Hi
I use separate 6631 on my Dual ak4399 . This has been maybe asked thousand times on other forums but is there any advantage using integrated Xmos on dac pcb Maybe better than 6631a ?
Old 3rd April 2014, 06:21 PM   #19
The xmos in the weiliang minishow is excellent, but I can't compare with cm6631.
Old 3rd April 2014, 06:27 PM   #20
Sunsun22's Avatar
Default Separating digital and analog regulator for AK4113
I modified a Dexa 5V to 3.3V tonight and installed it in the dual AK4399 DAC. It is no need to burn in the component because it is used. There are more details can be heard because the background is more quiet. The overall modification brings this DAC to more musical and is worthwhile to do so. I can't stop listening this evening and only find out it is already 2:30 in the morning.
ebay:Weiliang Dual X2 AK4399 DAC with LCDHide this!Advertise here!
DAC AK4399 + XMOS on Ebay luckyluke198x Digital Source 30 22nd February 2016 06:15 PM
Weiliang DAC9 with AK4399 risperdal Digital Source 541 29th October 2015 04:30 AM
FS : Dual AK4399 pinnocchio Swap Meet 5 4th March 2015 06:08 PM
WTB: Weiliang AK4399 or es9018 DAC lalka Swap Meet 2 3rd October 2014 01:37 PM
AKM AK4399 DAC PCB+IC on Ebay KlipschKid Digital Line Level 79 8th January 2014 04:26 PM
Copyright ©1999-2017 diyAudio
