| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
I am disappointed with one result, which may be more SACD technology related than player specific. The 563 is connected to a Denon 3803 through RCA cables. I also have an optical connection for movies. For SACD material (multi-channel mode), there seems to be no way to inject the information on the SW channel to the L and R. Hence, a subwoofer is a must. I have resisted getting a sub for music listening and would prefer not going down that path. The receiver does not process data fed through the Ext In connections. Therefore, I would wish that the 563 outputs L and R in full range, especially since the SW channel is set to Off. This does not seem possible. To my surprise, the SACD material I own (one of which the logo is above my name) seems to have a lot of content in the SW channel. Does the feature called Bass Management shown in the Pioneer Elite and Denon players solve this problem ? Any ideas ? Thanks... |
#12 |
I have a started a thread called Bass management circuits since my question is not about the 563, bur rather about processing the analog SW output...
#13 | |
Demir, Sorry I can't be of much help with multichannel. I have no intentions of using this player for any sort of surround sound, only stereo (even for DVD video). For SACD and DVD-A, I will only be playing them in hi-res two-channel mode, which doesn't not have the problem you posted above. In fact, I probably will disable/remove some of the multichannel circuitry. I plan to keep only a L and R rca jack for stereo out, a coax digital out (remove the optical out), and the S-Video and/or component video out). I may put in new, better quality jacks in the future, but I am only using a stereo setup. I'm sure others are in the same boat as you and want multichannel, so I hope they can chime in and give you a hand. Regards, Vinnie |
#14 | |
I have webspace that we can use to host the service manual if you can scan it. Probably the best format would be Adobe .pdf. --David |
#15 | |
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#16 | |
![]() What have you done to the power supply unit? I was thinking of starting at the beginning of it by changing the bridge diodes with HEXFREDs and replacing the 250V cap with one that has some more uF's. On the DC side of the power supply, some of those lower quality caps could be replaced with some Panasonic FCs (not expensive, but sound good). Maybe a little more uF's would be good, but I don't like to over do this on switching power supplies. I'm hoping to start next week. -Vinnie |
#17 |
I haven't swapped the diodes yet, and I haven't done much more than used a bunch of pulled PC MOBO 470-3300uf caps (rubycon, etc..I had swapped out the PC board caps for OS-CONS, to make the fastest PC boards you can get.....very expensive!!!) as replacements on the PS board itself. I have a box of HV caps somewhere, so I should be getting in there and swapping it out...
I re-did the divider's power supply with os-con caps. There are TWO dividers, one at the 27mhz chip itself and one on the last board before the BB1791 dac. I did this the same way as well. A slight change was discernable, but it was enough to make one want to do it. All the buffering of the PS was one at the chips in question and at the re-regulation points for the rails, near the affected circuits. I tend to look after the motor drive PS as well, as the noise and drain DOES come off of that same power supply....
#18 | |
As far as I know about these /DVD/ machines, 27 MHz is the main clock signal, used for Video and processing. Audio Clocks such as 24.576MHz and 22.xxxx MHz are Derived from this main clock with a PLL, not a DIVIDER /u cannot divide 27 to 24.576 / And some benefits and pitfalls:Jitter of the main clock is reduced or INCREASED to the one of the VCO in that PLL. To make it less, it is necessary to give the PLL a good clean Supply /u know that/. Most of the audio Clock generators, especially designed for this purpose, have 2-3 logic level inputs and a freq. input of 27 MHz - with 2-3 bits of static info they are told to set the output freq. to 22.xxxx or 24.576 or some else freq. - > i.e. they have fixed application , if I can call them so. TI and other manifacturers have such chips, they cost about $1..2 in high volumes - check out PLL1705/06 /i think/ and /?MT?/ 1412 The great problem is that these PLL's has a jitter figure of 75...300pS, which cannot be bettered no matter how clean supply u give them - assuming they have proper layaut and very close to the chip loop filter - look some AN's if interested -> this can be a significant up-grade, in not done well. For DVD-A and CD, ASRC and fixed freq. low jitter XO can be used to reduce jitter /AD1896 and Tent or Kwak or LC Audio Clocks/ - > this is the greatest solution for me. regards PS: the second chip is MK1412, used in the cheap DVD-737 from Phillips. Jitter is 190pS peak, acc. to datasheet. |
#19 |
Can anyone send me the service manual for this Pioneer??
regards- |
#20 |
well, it could have been leakage/noise -possibly the PS being used with the same DAC as well, or assocaited circuits. The sonics did improve slightly when the PS for both dividers was buffered with the better caps. Everything affects everything, as it always seems to be the case....
| Pioneer 563A - KBK, Vinnie R, Larry M | exolinear | Digital Source | 6 | 26th September 2006 02:22 AM |
| Poogeing The SACD (Part Deux): Shanling SCD-T200C | KBK | Digital Source | 7 | 1st December 2004 01:05 AM |
| Pioneer 563A Schematic | dtm1962 | Digital Source | 3 | 8th September 2004 05:18 PM |
| Pioneer 563A modding | fled | Digital Source | 1 | 15th August 2004 06:59 PM |
| Page generated in 0.13024 seconds (87.17% PHP - 12.83% MySQL) with 11 queries |
