Problem with XMOS output - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th October 2013, 03:42 PM   #1
triode_al's Avatar
Default Problem with XMOS output
I bought a Weilang XMOS card - 10 pins version that outputs I2S - to integrate is a TDA1543 DAC.
But I have some serious problems. The left channel is up and running, but the right is a square wave at best or a noisy popping signal.
  • Strange enough the output distortion differs per chip - I tested various chips on the DAC boards.
I attached XMOS card to DAC as follows:
pin 9, BCK --> pin 1 BCK input;
pin 8 DATA --> pin 3 DTA input
pin 7 LRCK --> pin 2 WS input
No attennuators.
As a test of the correct working I used a CAT6 interface between the Weilang XMOS and the DAC card; while I also had a CD player with an I2S output (grabbed from TDA1541 legs 1,2,3. With the input from the player all is OK; reverting to the XMOS card I have problems again. I inserted an ethernet male and female plug in between.
I used two DAC cards, both show the same problems with the I2S from the XMOS card.
Please, do you have any suggestions?
here are some funny pictures and these are not intended as art .
Nijntje TDA1543-XMOS 62 L1020683.jpg Nijntje TDA1543-XMOS 63 L1020684.jpg Nijntje TDA1543-XMOS 64 L1020685.jpg
while this the result for these same chips to the CD player:
hope to get some insights!
albert
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 16th October 2013, 07:21 AM   #2
triode_al's Avatar
Just to show what I am creating: a small package 'dongle'.
The USB connector and the RCA go out on the right side;
the power line comes in on the left.
I can then place it close to the notebook.
Old 17th October 2013, 08:54 AM   #3
triode_al's Avatar
Default I solved it!
I solved this mystery, by setting the MIDI interface (in MacOS) to 88.2 KHz.
Now both channels are up and running!
I will have a look how to force 176 KHz though, might be that there is some attenuation needed of a signal. The XMOS for instance outputs has a quite lower impedance than the SAA7220 for instance, with clear rise time and square waves.
  • It is a clear square wave, and the old Philips chip does not excel there.
  • The counterside might be some internal bounce (too fast rise time what might impact the second channel starting).
Xmos and AK4399 in single board ttan98 Digital Source 135 23rd April 2015 03:59 PM
New XMOS usb 384khz Nanoloop Digital Source 238 13th February 2014 08:48 AM
stacked with XMOS gana Digital Source 0 20th December 2012 07:28 AM
XMOS BAD sound? wizard1238 Digital Source 9 1st September 2012 08:06 PM
FS: WaveIO XMOS board pinnocchio Swap Meet 12 26th August 2012 09:10 PM
Copyright 1999-2017 diyAudio
