| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I was looking at the data sheet of the SAA7323 chip in my Philips CD624. It appears that there are two internal opamps (left and right) in the output section of this chip. I think this is called a 3rd order low-pass filter. The output after D/A conversion (switched capacitor integrator) is available at pins 10 and 44. It passes through a capacitor and resistor network and is fed back into the SAA7323 to the two internal opamps. The output of these opamps is then supplied to the analogue section of the CDP.
Q. Is it possible to take the output after D/A conversion and pass it through some better quality opamps for filtering instead of feeding it back into the SAA7323 chip. Q. If this is possible, does anyone know what opamps can be used here? Does anyone know if this output is current or voltage? If you can help, the data sheet is at SAA7323 datasheet |
| SAA7323 Vref pin? | jnewbold | Digital Source | 0 | 16th September 2008 02:35 AM |
| need help wana change 60-Hz twin-T notch filter to 279 Hz filter | prorms | Solid State | 0 | 9th February 2008 11:38 PM |
| External switched capacitor integrator (clear saa7323 datasheet needed) | ash_dac | Digital Source | 6 | 7th May 2006 11:21 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| chassis-mounted filter or IEC plug filter | jarthel | Solid State | 7 | 11th March 2002 10:17 AM |
| Page generated in 0.06620 seconds (64.93% PHP - 35.07% MySQL) with 11 queries |
