| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 | ||
#12 | ||||
Thanks for everybodys input! |
#13 |
You know that some of the DACs that are on the market have multiple internal ladder DAC's inside already. I mean what you really need to make this fly are DACs that that allow you to use your own voltage reference. Then you can scale the bits accordingly.
The other day I saw that TI now has a 16 bit video DAC, I kfor got the speed of the device.
Jim W. |
#14 | |
A normal multibit dac has a bit weight that scales with the position of the bit i.e. the weighting of the lsb of a 16 bit dac is 1/65536. As the wordlength increases the values required for the current sources get increasing smaller and more difficult and expensive to fabricate. The dCs ringdac has unitary weighted current sources ie. they all have the same value. The output current is formed by selecting the appropriate number of current sources and this is governed the control software. |
#15 | |
Anyway, this still is around 2.5 bits (=log2 (6)) times 64x oversampling, and I find it hard to believe that it can reproduce the full information contained in 16 bits samples... |
#16 |
If your looking to build a accurate high speed DAC you can do this discretely using the R2R ladder approach. I have found the controlling charge injection and current source to limit the accuracy in the design of Delta Sigma DAC.
The problem with building a R2R DAC is scaling the R2R ladders and producing a voltage reference that is stable with very low noise and low impedance. However, with S102 Vishay resistors the ladder not a big deal it just becomes costly. So building a DAC in this method is normally out of the question for the Burr Brown and Analog Devices due to cost, hence cheap Delta Sigma converters. There use to be several companies that made Hybrids DAC but they seem to have bit the dust; Hybrid Systems, MicroNetworks and Analogic were some of these companies. In addition, there use to be a number of resistor companies making R2R network on thin film substrate. Anyway, I have found during design and testing that the accuracy of these DAC's to be far superior to the Delta Sigma's since low level accuracy is compromised. So with a little effort multiple R2R DAC’s can be series together with a summing junction.
Jim W. |
#17 |
Could you post a simple schematic for a R2R dac ? I know I'm looking stupid, but I don't know whats that
![]() I know it's a ladder with many times R and 2R, I saw stepped attenautors like this, but what is used for switching ? CMOS switches as usual ? (charge injection etc) or something else ? |
#18 |
R2R ladder DAC are used in all types of applications where accuracy is needed.
Jim W. |
#19 |
Here is another R2R DAC one that may help you. As you can see the device allows you to use any Ref voltage and has options for bipolar outputs.
Jim W. |
| Why NOT to use these DACs for audio ? | percy | Digital Source | 14 | 17th February 2009 07:08 PM |
| Rf (Ch3 TV) to audio/video RCA conversion | jondavis | Everything Else | 1 | 19th January 2008 01:35 PM |
| Audio DACs, Instrumentation DACs. | Brian Guralnick | Digital Source | 10 | 3rd November 2002 04:56 PM |
| Page generated in 0.11018 seconds (82.30% PHP - 17.70% MySQL) with 11 queries |
