How to adjust Kwak clock? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th September 2013, 05:14 PM   #11
dmills is offline dmills  United Kingdom
Not exactly a low noise design, Colpitts for a low noise oscilator without any amplitude limiting?
Buttler or Driscoll with a series mode rock would be better (Much lower phase noise), or possibly something based on Chris Bartram GW4DGUs work on low noise vhf oscilators for microwave comms.
Also hit Wenzels site for some tricks to finesse supply noise issues.
Regards, Dan.
Old 29th September 2013, 05:51 PM   #12
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
Thanks for the reply,I had a pcb from Kwak laying around,and I have a Hiface EVO USB 2 spdif with external clock input.So I thought I test it and I made a PSU from a 2x12v trafo and a pos/neg lodroputregs.I havent yet tested the clock on EVO (Waiting on a BNC plug)
Where in this chain would the finesse fit in.After the Preregs or after the regulators on the
Kwak board?
Regards Åke
Old 30th September 2013, 04:40 PM   #13
Ryssen's Avatar
I will order some parts for Finesse and test..
Regards Åke
Old 30th September 2013, 05:18 PM   #14
merlin el mago's Avatar
Do you know the EVO clock frecuency?
Old 30th September 2013, 05:51 PM   #15
Ryssen's Avatar
It is 24.576Mhz for 48 and 96 and 192Khz.
Regards Åke
Old 30th September 2013, 05:59 PM   #16
So you can use Kwak clock.
Old 12th October 2013, 10:32 PM   #17
Ryssen's Avatar
I connected the clock to the Hiface EVO today but the green LED on EVO doesn´t light.
So I messaured the output on the scope and it´s only 2,5v I read that the EVO wants 3,3vpp to work,thats a problem...
Regards Åke
Old 13th October 2013, 10:18 AM   #18
Ryssen's Avatar
Is it possible to excange 2 (one on each side) of the 27k resistors in the regulators with trim resistors and raise the voltage to get higher output voltege?
Regards Åke
Old 13th October 2013, 05:33 PM   #19
Ryssen's Avatar
I got the clock working on the EVO but songs plays in the wrong pitch so I should have used a 22.xxxx x-tal.
I discovered that the signal was 3v before the 47ohm resistor at output but under 2,5v after so I shorted it....
Althow the LED didn´t light on the EVO the files played faster.
Regards Åke
Old 13th October 2013, 07:44 PM   #20
QSerraTico_Tico's Avatar
You need a fundamental mode crystal. Not all 24.576MHz crystals are fundamental.
Kwak Clock 7 help Honda Z50M Digital Source 2 17th May 2011 08:27 AM
My Kwak Clock 7 zygibajt Digital Source 12 28th November 2010 02:37 PM
Kwak-Clock-7 Honda Z50M Parts 3 29th September 2010 11:51 AM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
help with Kwak-clock jarthel Digital Source 5 4th May 2002 04:16 PM
Copyright ©1999-2017 diyAudio
