Is it possible to take the signal before optical for a coaxial digital connection? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th September 2013, 10:46 AM   #1
Nazo is offline Nazo  United States
Default Is it possible to take the signal before optical for a coaxial digital connection?
So I'm thinking of building a project where I would have a cheap USB DAC connected to a Fiio D3 to act as the actual DAC with a CMoy handling the analog stage. While it may be no substitute for the $200+ DAC+amps out there, it's pretty darned good in my initial tests. One piece of inelegance is very annoying though: connecting the USB DAC to the D3. Running a huge optical cable from one to the other and then having to switch them back and forth (or using a Y-splitter) isn't just ugly and messy, but it actually gets in the way and makes the whole package bigger and less portable.
I'm wondering: is it possible at all that the digital signal going to the optical converter is basically the same as what is used with coaxial connectors? Or, if not, could it be something simple like adding a resistor or capacitor or other such thing? If I could just run a couple of wires from it to the D3's coaxial input, I could have it completely internalized. It might be bad to have both the USB DAC and something else connected to that input at the same time, but I can't foresee having the USB connected AND an active coaxial connection at the same time.
Is it possible, or are they two very different things in this case?
I've attached a picture of the PCB from the USB DAC in case it helps determine anything. I circled the three pins that I believe go to the optical section of the TRS connector.
Old 26th September 2013, 11:06 AM   #2
atupi is offline atupi  Romania
My Egreat media player has only optical digital output and i obtained a spdif connection installing a RCA connector between GND and Signal of optical connector. Works very well for me. I have already a coupling cap on my DAC spdif input.
You can follow same way for your situation and it should work.
Adrian
Old 27th September 2013, 06:02 AM   #3
Ok, after a LOT of digging around and confusion since I've never done anything remotely like this I managed to find a data sheet for the VT1620A and figure out which pin of the three is the signal. In fact, it explicitly states "SPDIFO" for pin 28 in the datasheet. After following the trace, failing, and using a multimeter and a magnifier and a very very steady hand, I managed to identify connector 3 (the bottom one) as being the SPDIF signal and soldered in a connector with RCA on the other end. After not so bravely forcing myself to flip the switch, it worked. No smoke, just clear clean audio.
Thanks. I am curious, is there any danger if there were two SPDIF signals connected at once to either the USB DAC or the D3? I seriously doubt I'll ever have both at once, but I'd like to at least hear that the whole thing won't go up in flames if I did accidentally do it...
How to convert optical to coaxial digital output? marchel Digital Line Level 4 24th June 2010 12:33 PM
optical coaxial connection mhtplsh Solid State 1 17th May 2008 01:16 AM
FS: Digital Signal Converter- Optical in Coax Out akunec Swap Meet 0 16th May 2007 07:04 AM
Problem: intermittent optical digital signal dropout? faustian bargin Digital Source 0 6th April 2004 09:21 PM
Circuit to convert coax digital signal to optical? bobo box Digital Source 17 9th March 2004 11:01 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
