Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Feixiang FX-98s PCM2704 + XR1075 +QS7779 USB DAC
Old 9th January 2014, 05:18 AM   #11
roggom is offline roggom  United States
I will post the pics within the next few days. It was a simple jump of the opamp. Now if you desire to use as a headphone amp, maybe try a higher value resistor as the increase of feedback lowers gain, but seems to push the noise floor a little higher (when using headphones). As a preamp, the sound is very transparent with the volume knob from low to mid level.
I do still hear the 1 khz, but I have not troubleshot with my scope yet. I honestly believe it is the PCM clock that is causing the noise.
I removed the XR1075 chip and the noise is completely gone, that is because it breaks the signal path , so I can only assume the origin is before the xr1075. I did some trace routing, but it is very difficult with black mask over the board.
I am sure with a little more troubleshooting, the noise can be illuminated, but my guess is the PCM/DAC must be disabled to do so.
Most of my Google searches for DAC hiss, suggested upgrading DAC's. There just has to be a way to illuminate it, either by upgrading to a much better opamp, or active filtering.
we will see.
Old 28th January 2015, 06:07 PM   #12
Cobra71 is offline Cobra71  Germany
Cobra71's Avatar
That sounds interesting, I get mine next week and I have a dso so I can search the 1khz too.
Regards from Germany
Marc
I don't pay for Voodoo...I like turntables, Tubes and diy.
Old 3rd February 2015, 09:53 AM   #13
Cobra71's Avatar
I got my FX98 yesterday and I had not much time.
I plugged it to a regulated 12V PS and to USB of my PC.
I tried it with Headphones (Beyerdynamic DT880 Edition 250 Ohm) only and the sound wasn't bad, and I heard no 1Khz Sound.
I downloaded the specifications of the BB2704 and I saw that the chip has SPDIF out at Pin 5 and 6.
http://www.ti.com/lit/ds/symlink/pcm2704.pdf
I will add a SPDIF out, that will be done fast.
My next test will be with line in and out.
Marc
Feixiang FX-98s PCM2704 + XR1075 +QS7779 USB DACHide this!Advertise here!
[PCM2704:USB->SPDIF]Schematics, capacitors maximilliangreat Digital Line Level 0 26th January 2013 12:02 AM
Tiny USB DAC (PCM2704 based) Calamaro Digital Line Level 15 8th May 2012 04:21 PM
USB sound card with PCM2704 - need PCB lorik199 Parts 8 21st September 2011 11:11 AM
USB Audio controlling PCM2704 new design jash2008 PC Based 5 7th June 2011 02:23 PM
PCM2704 DAC Complete ble0t Digital Source 0 9th February 2006 12:02 AM
