Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
TDA1543 semi-parallel solution
Old 15th October 2013, 08:18 AM   #81
triode_al is offline triode_al  Netherlands
triode_al's Avatar
EC designs likes to connect the output to the source of the current, being Vdd.
This is also easily achieved
  • by connecting the output I/V resistor to Vdd, and because it supplies 1,2 mA the value can be calculated to e.g. 3k3 @ 7V. The output will be too high then, full scale current being 2,3 mA.
  • Or 2K @ 5V which might just give almost 5Vpp.
Some enhancements can be thought of in this case
In the drawer, not the bottom one.
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 26th December 2013, 07:36 AM   #82
av-trouvaille is offline av-trouvaille  Netherlands
Triode_al,
In your interesting post 69 the schematic mentions LC272 as opamp.
May I assume any opamp will do that is capable of asymmetric power supply?
Or even an opamp in symmetrical power supply if available?
Old 29th December 2013, 08:18 AM   #83
triode_al's Avatar
Originally Posted by av-trouvaille View Post
Triode_al,
Sorry, I have not tested other asymmetrical power supply- opamps, as I found this opamp in a dump (kwakkelstein) so it was a real trouvaille for me
And I did not have an asymmetrical power supply in my build.
The goal is to be able to have a real step, and then apply a little bit of filtering.
Old 29th December 2013, 09:22 AM   #84
Thanks. I will have a try with other opamps.
OT: What a coincidence you mention Kwakkelstein, as my diyaudio name was inspired indeed from the period many years ago I frequented him and gathered lots of trouvailles. I wonder whether the warehouse he retreated in is still open these days.
TDA1543 semi-parallel solutionHide this!Advertise here!
4 x TDA1543 parallel dac schematic noyan Digital Line Level 25 24th July 2017 06:57 AM
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 05:50 PM
winISD calcs: parallel vs series-parallel sadams Multi-Way 1 20th February 2011 07:45 PM
Parallel TDA1543 + DIR9001 DACs Netdewt Digital Line Level 2 29th January 2010 04:59 PM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
