TDA1543 semi-parallel solution - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th September 2013, 01:07 PM   #21
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
No experience of using 1543 with active I/V, no. I'm firmly converted to the passive I/V camp now though I do sometimes use a common-base transistor if I'm after a tad more output compliance...
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 8th September 2013, 05:07 PM   #22
DF96 is offline DF96  England
Does anyone have any measurements of improvements when Vref is left o/c? If the internal current mirror has a flaw then this ought to show up in noise or distortion tests.
Old 9th September 2013, 01:33 PM   #23
triode_al's Avatar
I tested awith Vref open with a Vdd of 7 volts,
  • with the chip I tried there was no output, that one chip did not fire up,
  • and that chip died, because when I connected to a resistor it did not come above 0,9 volt on the pin.
  • . . could be the chip was dead on arrival, but should I try a second time with another chip?
Could well be that at Vdd of 5V this does work . .
But I tested and there was no output; voltage on pin 7 was 2,25. Tried various output values (pot).
So I'm puzzled at what the mod of leaving it open really is
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 9th September 2013, 01:52 PM   #24
If you leave Vref o/c then you must make proper arrangements for Vout such as a potential divider - you can't just put a resistor to ground as you have no balancing current from the internal source. TDA1543 normal output current is a data-controlled sink, not a source. That is why we normally need to use the internal current source to balance it.
Old 10th September 2013, 01:36 PM   #25
triode_al's Avatar
abraxalito, saw your anti-imaging filter. Nice!
What is the approximate output impedance of the TDA1543, dynamically? This is for calculating a filter that would start with R/C then L/C to obtain an 18 dB/oct LPF that is simple;
for instance.
I like you latest filter, looks a bit complicated even though I have an L-meter.
  • [internal resistance+external resistance, aimed at totaling 120 ohms]/27nF = approx 46 kHz
  • 1mH/12nF = approx 45 kHz
So my question is: what series output resistor to add to aim at e.g. 120 ohms?
Old 10th September 2013, 01:49 PM   #26
abraxalito's Avatar
Thanks, nice to know someone is appreciating my blog
I reckon its effectively the I/V resistor's value as its presumably an open-collector whose output impedance will be an order of magnitude or more higher than the I/V resistor.
The one I've been playing with most recently is a single inductor value filter, so no L meter is called for as it can work with not-so-very-precise values available off the shelf. The most recent incarnation of this uses Coilcraft 3.3mH SMT coils about 6mm square, 8 per channel. If you'd like the schematic I'll put it up on the blog. Its load impedance is 270R but if you want to work into a different impedance, just scale the inductor values linearly with the chosen load resistance. Say to work into 120R the inductors would become 12/27 * 3.3mH = ~1.5mH. If you don't feel you need the steep slope offered by 8 inductors you can always shorten the length as its using repeated stages which are identical.
Old 10th September 2013, 02:03 PM   #27
triode_al's Avatar
Default TDA1543 USB dongle!
A dongle being a little interface with cords, that is what I envision now:
one cable to the power supply and output cinch [CAT6 cable], one cable for USB, as short as possible.
Very compact is possible.
This is how it can look with an XMOS I2S card:
in the little box,
where one side will have a little USB cord dangling (dongling?) out - so this little box goes close to the PC;
A closeup of the card/card interface, with possible output capacitors to the right:
Resistors not attached in this concept.
Old 10th September 2013, 02:56 PM   #28
triode_al's Avatar
I have 4 chips now parallel each with 1700 Rout; so it is effectively 425 ohms.
Then I tap each chip with a 200 ohms resistor to a common point with a capacitor of about 6,8 nF. This gives 49 kHz and is intended to be the first pole. I use this summing resistor to keep the outputs somewhat independent in DC level. The four chips differ several tens of mV on the output.
The problem is I can't measure in anyway what the LPF frequency is . . .
For me the 8 steps steepness is a bit overdone but it depends on using NOS or (some) OS - and on pre/amplifier and speakers.
I want to go at least 2-times Interpolation and Oversampling in the PC, so my case is more like the one on the right than on the left:
Attachment 370420
The diagram: The shapes on the right are the images we want to reduce.
For me I think and LFF or 45 kHz of 18 dB in total is rather good as the images would be at 160 kHz if I understand it correctly. And I have some stock 1 mH chokes at hand
Old 10th September 2013, 11:10 PM   #29
abraxalito's Avatar
You're right that going for 2X OS you don't need nearly so steep a filter as for NOS. I got an 'invalid attachment' message so can't see your piccy but with 2X OS your images will start around 2*fs-20k = 68kHz. At a guess a 2 inductor filter should be sufficient. I could have a stab at designing it for you if you tell me what the DCR of your 1mH inductors is.
Old 11th September 2013, 10:16 AM   #30
triode_al's Avatar
You're right that going for 2X OS you don't need nearly so steep a filter as for NOS. With 2X OS your images will start around 2*fs-20k = 68kHz. At a guess a 2 inductor filter should be sufficient.
I have tried by trial and error but just 1mH/15nF has too low a Fc, even with 10 nF it is (sweep). The attenuation at 20 kHz is already 1 dB, this is not a wanted outcome.
Great. My 1 mH chokes have a DCR of 12 ohm. I also have 27 mH with a DCR of 170 ohm. The output impedance after the DACs is 507 ohm.
Picture:
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 06:50 PM
4 x TDA1543 parallel dac schematic noyan Digital Line Level 23 11th February 2012 03:37 AM
winISD calcs: parallel vs series-parallel sadams Multi-Way 1 20th February 2011 08:45 PM
Parallel TDA1543 + DIR9001 DACs Netdewt Digital Line Level 2 29th January 2010 05:59 PM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 08:12 PM
Copyright 1999-2017 diyAudio
