Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
marantz cd65 mkii random stopping
Old 14th August 2013, 10:21 AM   #11
Mooly's Avatar
Yep, SYSCON is system control
It does sounds an uncommon or "one off" type of fault with the drawer doing what it does but as with most faults, dries and PSU issues are favourite. Obviously make sure any mechanical issues are attended to first such as checking and cleaning leaf/micro switches. Any large IC's are the very last things to even point a finger at, it will be something else.
Old 14th August 2013, 01:02 PM   #12
tomst is offline tomst  United Kingdom
well I't seams it's a problem bought on by heat. yesterday it was in a cabinet with closed in back though there was a fair amount of space round it. It's now been plying faultless for hours out in the open. looking at the psu how tight it is and the temperature in there and from what has been said i would hazard a guess at a voltage regulator or capacitor. when i had the PCB out I visually checked for any obvious problems like lifted tracks and dry joints. I'll probably replace some of the 47F caps anyway esp the one mentioned.
Old 14th August 2013, 03:33 PM   #13
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
I might be wrong but, from memory, the original cap doesn't cause problems, but an inappropriate replacement can. A cap with very low ESR shouldn't be used there. Nor should one be used immediately following a voltage regulator, by the way.
These machines sound good but they're flimsy and awkward to work on. Because of the weight of the transformer fixed to the circuit board, it tends to flex a lot during handling. If you need to take it apart again, check the traces and soldering around the transformer for cracks.
They aren't safe in the post for that reason. If the machine flops onto its back, the transformer screws rip out and total carnage ensues
Philips plastic declined sharply in quality IMO. Good heavy transformer though.
Old 14th August 2013, 03:56 PM   #14
when i did the psu I replaced the main caps with panasonic FC capacitors after the regulators with panasonic FR so they have quite low ESR would a the FC or something with even less better after the reg?
Old 14th August 2013, 05:16 PM   #15
Mooly's Avatar
Its still all guesswork but from what you say replacing the 78/79 regs might be worthwhile. Unless you can observe a problem (scope which you haven't access too) then its a case of second guessing the issue.
Old 14th August 2013, 07:06 PM   #16
Ok I'll go for the regulators. do they have to be the 78/79MXX type or can they be standard type eg7905. After a quick look it seams the M stands for medium current.
marantz cd65 mkii random stoppingHide this!Advertise here!
HELP! Marantz cd65 MKII fault antony28 Digital Source 8 8th July 2014 09:49 AM
advice needed (regarding MARANTZ CD65) liquias Digital Source 7 19th September 2010 09:12 AM
Service Manual Request: Marantz CD75 MkII or CD65 MkII jeff mai Digital Source 9 23rd April 2009 04:48 PM
Marantz CD65...keep,upgrade or replace? rmsmax Digital Source 7 20th January 2009 08:01 AM
MarantZ CD65 seting-up? ZuMbAiU Digital Source 2 12th March 2006 03:58 PM
