Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Yamaha CD-S700 Opamp upgrade (OP275) : hints ?
Old 19th August 2013, 10:32 PM   #21
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
OPA275 is a JFET input opamp and it sounds decent. OPA2604 is not an improvement. Maybe replacing them is not a very good idea ? I would never replace them for bipolar types for offset reasons. Although I never use sockets maybe it is a good idea to use those in this machine to try stuff out without damaging the PCB.
BTW muting transistors really have influence on sound quality as capacity varies with voltage on them. Removing them will give better results in most cases. Micro-relays are way better but they're too slow when uncorrectable errors occur. They are good for muting power on plops and clicks though. Good thing is that they connected emitter to signal lines. I have seen worse.
My advice is to replace the output caps for MKT ones with 5 mm pitch like the Wima MKS2-XL types. Worthwhile upgrade, better than most electrolytic caps.
It's only audio. Member of the non modular PCB design committee
Old 20th August 2013, 08:34 AM   #22
marble88 is offline marble88  France
Originally Posted by jean-paul View Post
BTW muting transistors really have influence on sound quality as capacity varies with voltage on them. Removing them will give better results in most cases. Micro-relays are way better but they're too slow when uncorrectable errors occur. They are good for muting power on plops and clicks though. Good thing is that they connected emitter to signal lines. I have seen worse..
Hi Jean-paul, what would be your advice regarding those transistors : keeping them or removing them ? They are smd transistors.
I was planning some Elna ARS-A (super gold) 100uF or some Elna Cerafine BP 10uF. Do you think Wima should better them ? In this case what value should be fine ?
Old 20th August 2013, 12:13 PM   #23
jean-paul's Avatar
Hi, I always remove them but be prepared that if you have scratched disks you can hear severe clicks/plops. Since I am cautious with all my stuff it was never a problem in my case. I would add a small relay for muting the outputs at power on and off.
I prefer MKT/MKC/MKP film caps over electrolytic caps anytime (except when they're BG). They never need replacement as there is no electrolyte that dries out.
MKS2-XL exist in 10 uF. I have bought the very last batch of MKS2-XL 22 uF 16 V a few years ago from Wima and use those with good results. Largest cap with 5 mm pitch in the world !
Old 20th August 2013, 01:56 PM   #24
Fine jean-paul, you convinced me. About muting transistors, I am cautious too but my wife cd's are a bit "more or less". Because I am planning some upgrade above this player in the near future so that this one will may end in her system, I'll keep the transistors working so far...
Old 21st August 2013, 04:38 PM   #25
odnaizutra is offline odnaizutra  Guyana
also had problems with muting bipolar transistors .will try another
option.
Old 3rd December 2013, 07:13 AM   #26
ronensh is offline ronensh  Israel
Hi guys,
I just purchased CD-S700, and this thread is very interesting.
I can't find a pdf of the service manual.
Can anyone help?
Thanks,
Ronen
Israel
Old 3rd December 2013, 07:20 AM   #27
Found it !
Thanks anyway.
Ronen
Yamaha CD-S700 Opamp upgrade (OP275) : hints ?Hide this!Advertise here!
op275 upgrade justpoor Digital Source 13 15th April 2014 10:54 PM
Some questions about Yamaha R-S700 receiver ramiro77 Solid State 1 23rd May 2012 09:22 PM
OP275 opamp replacement help. Glen1 Digital Line Level 26 31st March 2012 08:58 PM
FS: Yamaha CD-S700 CD Player doucanoe Swap Meet 4 2nd September 2011 12:34 AM
CD player opamp upgrade -advice needed stevew7280 Digital Source 9 8th October 2010 07:02 PM
