16bit i2s 48khz Source to SRC4192 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th July 2013, 07:57 PM   #1
djwenne is offline djwenne  Germany
Default 16bit i2s 48khz Source to SRC4192
i have an Audio Source 16bit 12S 48 khz and want convert this to 44.1 khz. I know i must use an SRC like the 4192 from TI.
On the Datasheet i cant find any settings for an 16 Bit I2S source.
Works 24bit i2S?
Any Idea how to do this? Thanks...
Old 29th July 2013, 11:40 PM   #2
wa2ise is offline wa2ise  United States
wa2ise's Avatar
You could stuff zeros for the 8 least significant bits, to make the 16 bits look like a 24 bit signal. Assuming the data rate conversion uses a "poly phase filter", most if not all of the new samples will be 24 bits, the 8 LSBs not all zeros.
Old 30th July 2013, 04:41 PM   #3
Default Hi from a fellow ham
Off topic... Hello from AB0N
Old 31st July 2013, 12:30 AM   #4
Default Problem Fixed
Hi again,
i found it out. The SCR 4190/ 4192 works in I2S Mode from 16 bit to 24 bit.
It`s not necessary to do something self :-)
- closed -
Ultimate Open Source XMOS USB-I2S: The source to end all sources. krfkeith Digital Source 4 14th June 2013 04:54 PM
how to convert my itune files (alac 16bit) to 48khz or higher msj965 Software Tools 7 16th February 2012 01:38 PM
MiniAMP i2s source pir8don Digital Source 0 29th November 2010 12:04 AM
I2S: Relationship between SCK and Fs (targeting SRC4192) afo Digital Line Level 4 2nd September 2010 07:28 PM
I2S source switching? mbcouple Digital Source 2 4th November 2006 09:54 AM
Copyright 1999-2017 diyAudio
