Im trying to set a voltage source to give me a square that is +1/-1V. I have got the supply to go from +1 to 0, but I cant work out how to make it negative. Is there some way of adjusting the y axis?
you need a negative supply, or floating center tap/ground reference, to allow a +/- power supply. if you are unable to get a negative swing from a positive supply, thats no surprise
