Xmos and AK4399 in single board - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th December 2013, 01:30 PM   #11
hates ground loops
Rodeodave's Avatar
Max Martin, what version is your DAC pcb? There supposedly is a v1.1 version out now.
Did you get a schematic with your DAC perhaps?
Gravity - Making the G since 13.7 billion B.C.
Old 25th December 2013, 04:35 PM   #12
Max Martin's Avatar
It's 1.3 bought from minishow.
Yes i got a schematic.
Old 25th December 2013, 09:44 PM   #13
ttan98 is offline ttan98  Australia
From Martin's review and my requirements, I have placed an order for 1 unit of this board, hope it doesn't disappoint. I do have a few DACs I can compare with,
1. WM 8741 with CM6631 via digital coaxial
and
2. AK4393 and Xmos via I2S
all these DACs are std configuration without extensive mod., I use tube buffer attached to the DAC output. I will be using this new DAC(AK4399 and Xmos) with tube buffer and CDrom build into a single box.
Old 25th December 2013, 10:32 PM   #14
hates ground loops
Rodeodave's Avatar
May i ask where, and which version?
Old 26th December 2013, 01:33 AM   #15
I bought it from Minishow0328, do a search at Ebay, they are away at the moment, as Max said, his version is 1.3.
Old 26th December 2013, 08:23 AM   #16
Max Martin's Avatar
I wouldn't go with a tube buffer with this one i think. This dac sounds very analogue already.
Remember some mods to do right away if you want it top class.
1. Op amps to opa228
2. Remove bypass on opamps: more coherent. (Or change to ero 1837)
3. If you can replace bypasses to ero mkp1837.
Remember burn-in: maybe 50-100h atleast... And if you want a cleaner, brighter sound , Cerafine on output. I have now filmcaps and that is the best - but bulky.
Old 26th December 2013, 09:23 AM   #17
hates ground loops
Rodeodave's Avatar
I saw that they are away, that's what had me confused. I thought you had just bought one, but my search came up empty. Guess I'll have to wait then.
Old 26th December 2013, 07:54 PM   #18
Just bought it a few(3-4) days ago and it is on the way to me.
Old 26th December 2013, 08:02 PM   #19
Thanks for the suggestions, my "hypothesis"(*) is that without extensive mods as suggested by you and I put a tube buffer in front of the DAC, the sound reproduction would be similar to your mods without the tube buffer.
* I put a tube buffer in front of my unmodded AK4393 and WM8741,using standard opamp(yet to experiment with other op-amps), both sounded more analog.
Old 5th January 2014, 06:25 PM   #20
I'm interested in getting this - presently have a hifime ES9023 USB DAC.
I run my system off a Mac Mini - does the latest minishow version with the XMOS USB input work with a Mac? Anyone tried?
industrial single board computer karma Swap Meet 4 3rd November 2016 02:57 AM
Weiliang DAC9 with AK4399 risperdal Digital Source 541 29th October 2015 04:30 AM
Connect XMOS ref. XS1-L1 to ES9018 Evaluation Board ghmfranken Digital Line Level 2 10th February 2013 03:25 PM
FS WaveIO board (USB asyinc XMOS) Telstar Swap Meet 7 12th January 2013 02:06 PM
FS: WaveIO XMOS board pinnocchio Swap Meet 12 26th August 2012 08:10 PM
Copyright 1999-2017 diyAudio
