Crackling sound in right channel of TDA1541A DAC Crackling sound in right channel of TDA1541A DAC - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th December 2003, 01:42 PM   #1
HeadSh0T is offline HeadSh0T  Canada
HeadSh0T's Avatar
Default Crackling sound in right channel of TDA1541A DAC
I just finished building a TDA1541A based DAC using Guido Tent's clock and Pedja's AD844 IV conversion (schematic below). However, upon start-up, I noticed that there is a crackling sound in the right channel during loud passages in the music.
After about 20 minutes of playing, the crackling disappears.
I found a thread that described a similar problem and the problem was traced to a leaky output cap. So, I changed my output caps and still, there is a problem.
Any ideas?
Here's a link (the pic is not so good).
http://www.geocities.com/react_71/au...a1541a_dac.htm
Old 9th December 2003, 01:52 PM   #2
rbroer is offline rbroer  Netherlands
rbroer's Avatar
Check the DC level on the TDA1541A outputs when just turned on and after 20 minutes.
Rudolf Broertjes
Old 9th December 2003, 03:16 PM   #3
Pedja is offline Pedja  Serbia
Hi HeadSh0T,
Sounds like the effect that sometimes occurs as a consequence of the non-filter approach (if it originates downstream the (pre)amp channel swapping will reveal this). But it is interesting it disappears after 20 minutes. Try the channel swapping inside the DAC to determine is it related to the TDA1541 or the AD844 and observe the voltage drift at the output.
Good luck,
Pedja
Old 9th December 2003, 10:16 PM   #4
HeadSh0T's Avatar
Thanks guys for your help but it was Scott Nixon whose email provided the answer. I had a cold solder joint on one of the 14 caps.
This is what he said:
When I used to repair Philips cd players, this type cracking noise while cold on one channel, was almost always on of the 14 caps around the dac with a cold solder joint, or one or two times I remember replacing the caps (suface mount) to get rid of it. If you'll re-heat those joints on those caps, she might just behave.
BTW, i have about 20mV DC before the output caps when it just turns on.
Crackling sound in right channel of TDA1541A DACHide this!Advertise here!
Crackling noise in left channel. fritz39 Solid State 1 20th January 2009 11:57 PM
Sony amp one channel crackling dayking79 Solid State 14 11th December 2008 08:54 AM
crackling sound from one channel ali_azamkhan Tubes / Valves 4 23rd November 2007 09:43 PM
Tube Amp - Crackling Sound on Left Channel Noak Tubes / Valves 8 28th December 2005 01:46 AM
crackling sound CDM 4 Thomas Hage Parts 4 8th November 2005 07:06 AM
Copyright ©1999-2017 diyAudio
