Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Who stacked PCM63 ?
Who stacked PCM63 ?
Old 5th July 2013, 09:08 AM   #1
Arno Pf is offline Arno Pf  Netherlands
Default Who stacked PCM63 ?
....and did some measurements...listening....
And has some...thoughts, ideas, advice etc?
Old 5th July 2013, 09:53 AM   #2
For a start...they did But still measurements missing
http://www.diyaudio.com/forums/digit...back-mode.html
Old 6th July 2013, 03:32 AM   #3
Extreme_Boky is offline Extreme_Boky  Australia
I liked PCM63 a lot. This is AN DAC3 if I can remember correctly. It sounded kind-of ok with single DAC; staking them required few changes and adjustments... The stacked sound was much better, faster, more detailed with much better low and high extension.
Boky
Old 6th July 2013, 05:16 AM   #4
Boky
Thanks a lot! Nice implementation...straight on top or some pins independently connected to the board?
Did any measurements?
Old 6th July 2013, 10:23 PM   #5
To answer the topic question....I did...today!
Old 8th July 2013, 03:37 AM   #6
ihear21khz is offline ihear21khz  Malaysia
We ran paralleled PCM63s on Sheldon Stokes Tubed dac design many years ago. The way we did this was exactly as you have done. However, later on we found out that this isn't the best way. We attach some info we got from the Internet on the proper way to parallel the PCM63. We have not tried this method as we now use PCM1704s in our projects.
David
Old 8th July 2013, 06:23 AM   #7
David
Hi, I saw this information in the topic on the forum. Thanks for collecting and psoting it in the document!
Who stacked PCM63 ?Hide this!Advertise here!
stacked with XMOS gana Digital Source 0 20th December 2012 07:28 AM
Stacked Ribbon? dhenryp Planars & Exotics 12 23rd September 2012 07:05 PM
stacked dahlquist dq10 SPEAKERMD Multi-Way 0 14th July 2011 04:30 AM
Can Toroidals be stacked? ben62670 Power Supplies 16 21st June 2008 03:47 PM
Stacked woofers dsrviola Multi-Way 1 15th October 2006 03:35 AM
Copyright ©1999-2017 diyAudio
