Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th December 2003, 06:19 PM   #21
Lucas_G is offline Lucas_G  Netherlands
Default Re: Are you using LT1085?
Originally posted by Fabian
Lucas,
I've also built Doede's dddac. In the beginning all I could hear was a lot of noise but almost no music. Quite similar to your description. It took me more than a day to find the problem: LT1085 just didn't work (although it measured well). After replacing with a LM317T it worked fine.
BTW: Doede recommends 3.85V, not 3.5V as you mentioned in post #6
Fabian
Hi Fabian,
Now that is some news!
I will order some LM317s too.
Lucas
Originally posted by Jax
LT1085 needs at least 150uF on the output if a bypass capacitor is used on the adjust pin. A 10uF is also needed on the input pin to ground since the distance to the source is significant. Else it may oscillate.
LM317 is more stable but noisier and need no capacitor at all on the output.
Hi Jax,
So this expensive LT1085 is pretty difficult ot handle...
I will try your solution too. If two persons point at the 1085 being the problem, it is worthwile to try this.
Thanks.
Lucas
Old 11th December 2003, 06:23 PM   #22
Originally posted by jewilson
You should be using a buffer somthing like a 74ACT244 to drive all those DACs. That's to much of a load on the 8412.
Also, check to make sure you have set modes M0,M1,M2, M3 correctly. The can change with different DACs.
Also, change filter cap on the 8412 to a .047uf film cap, don't use an electrolytic there.
Hi Jewilson,
It DOES work with 8 TDA's in Doede's own setup...
Lucas
Old 11th December 2003, 06:26 PM   #23
Originally posted by finneybear
Lucas, if the problem existed already when the DACs were cool, then I am running out of clue as well. Probably you just have to try the simple but dumb way... replace the parts one by one to see how it goes.
The Doede board looks good to me already. Yet if I have to make a new board myself, definitely I will add more buffers to the 8412 and reroute the ground.
The 4x2 idea goes this way: A is for the top, B for the bottom. The arrangement looks like: ABAB. This will ensure any two adjacent sets will always share one side to have the shortest signal path. Now I will have to come out a good way to connect the right signals together. Probably through p2p shielded silver wires? Another good thing about this topolgy is that there will be no signals go between the pins. I can put ground lines around them instead.
It will be easy to install heat sinks as well. Probably no need for a fan anymore.
Hi Finnybear,
Yes, I guess I will alaso have to exchange the 8412...
Desoldering the current one will be a nice job...
BTW, with the aluminium tower that I constructed, you can also get away without a cooling fan, as long as you attach some decent heatsinks (3 x 5 x 1 cm) on the sides of it.
Lucas
Old 11th December 2003, 07:08 PM   #24
Can you test the CS8412 on its own? If you have a LED connected to pin 25 it will go out when the CS8412 locks to the data.
ray
Old 11th December 2003, 08:27 PM   #25
Send a message via AIM to jewilson
Default Loading
Lucas_G
I do not know what the input impedance of the DAC looks like now, but you have severely reduced the input impedance by a bunch. Crystal has not rated the output current for the clock and data outputs on this part, however you should not be driving this many gates from the 8412, it is just a poor design practice to do that.
Next, issue with this implementation you are slowing the down both devices due to the load. This will reduce the rise time at the DAC's input and can make the converter more susceptible to jitter.
Try adding a buffer there; you might be surprised to here the difference. Also, ground the input to the unused gates.
Jim W.
Old 12th December 2003, 11:08 PM   #26
Lucas, I am afraid that the heat is still a concern. The chip may be a bit cooler outside but the internal junction temerpature may be still too high. DAC chips performance is very sensitive to heat actually. Since I will redo the PCB, the new 4x2 arrangement will give me some edge on both heat dissipation as well as signal feed quality. I want to create a topology such that the signal paths from 8412 to the 8 1543 all have equal length. A buffer or two between them. The output of the reclock circuit is a concern, too.
Old 13th December 2003, 11:36 AM   #27
Hi finneybear,
I will be very interested in such a redo of the pcb!
Maybe we should also consider to place 4 times 2 chips on the underside of the pcb. With alu strips between them, we could press the aluminium on to the bottomplate of the enclosure...
Lucas
Old 14th December 2003, 12:43 AM   #28
Hi Lucas,
The 1543s can not be all on the same side otherwise some signals will have to go between the pins. ABAB is still the best way to go, I think? Every two sets can still share one heat sink. A memory chip heat sink can do the job. I still have to sit down and think about a way to get equal signal path length. A tiny clock skew to different 1543, for instance, will have impact on the sound image, etc. Even the DAC tower solution has this problem.
Old 14th December 2003, 11:27 PM   #29
dddac is offline dddac  Germany
Hi Lucas,
I see you are still trying to get your problem fixed....
Looking at all the reactions, you may be understand now, why I cannot give support from a distance..... I had one DDDAC1543 builder with the problem that nothing worked !! The solution was to remove a small splitter of metal on the datatrack !! There is no way you can find things like this through email.
I also noticed that your request for help post has also encouraged people to start proposing redesigns and tweaks, not to mention statements on how the dac is supposed to work and not work.... This is clearly not helping you and you seem not to have to the means to do so, which I regret. If you like you can send the DAC to me and I will fix it for you.
In the meantime: many builders have finished the dac and are very happy with the results, even with poor ground designs or cs8412 loads which are too high Don't get yourself distracted. The set up works fine and gives a much better result than the cost would justify....
Oh, I use the 1085 myself......... with 22uF Black Gate. The datasheet recommends this value (10-22). If you use a cheap electrolite, this might proof to be too low. so have you tried a 220uF (just to make sure) at the output from the 1085?
any way my offer stands.....
take care
doede
Old 15th December 2003, 09:26 AM   #30
Hello,
I have problems as well:
When I put my dac tower in, the LT1085 does not hold his voltage, without dac tower I have the 8.5V, with dac tower it drops to 1.87V or so.
When I remove the dac tower and put in one dac, and change Rsource to about 2k and change Rref to get to 3.85V DC output I get a nasty osclillation of about 50Mhz 2v top-to-top on the output. However when I turn on my cd-player the dac works. When I turn down the input voltage (I run of a stabilized variable power supply instead of a battery) to about 8V (the LT1085 does not have to do anything anymore) the oscillation stops! And the line out looks nice! When I put the tower back in, everything stops, 1.87V on VA2, nasty oscillations on the power supply rail etc.
So there is something wrong with this LT1085 thingy! By the way I use dirt as sh*t 22uf 35V elco's instead of BG because the BG's are in backorder! I will raise the elco's to 100uf or so tonight...
Edwin
An Odd Duck -- Gibson BR-6f Guitar Amp Teh Gav Tubes / Valves 5 5th February 2009 04:45 PM
Jung Super Regulator in Doede's 1543 DAC audionut Digital Source 0 26th February 2008 05:43 PM
Dead Duck circuits 7n7is The Lounge 0 15th October 2007 04:36 PM
Doede DAC..reclocked or not? Bas Horneman Digital Source 9 16th February 2004 10:53 PM
Stuck on reclocking part of Doede's 1543 DAC Bas Horneman Digital Source 12 5th February 2004 01:52 PM
Page generated in 0.13052 seconds (82.55% PHP - 17.45% MySQL) with 11 queries
