| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Maybe the cdm12.4 transport mechanism will work in the CD63? Does anyone know if they are compatible?
#12 |
Marantz supply a different mech as a service replacement - I'll check tonight which model it is.
Andy. |
#13 |
Marantz supply the VAM1201 as a replacement mech for CD63's, along with some new clamps which are needed if replacing a CDM12.1.
Andy. |
#14 |
Hello!
Does it include the sledge, too or do you use the one from the old mech? What would it cost? Cheers, Tom |
#15 |
Mechanism includes the sledge. Cost depends on where you buy it and it is between 25 and 50 EUR.
Btw, my CDM12.1 is replaced by VAM1202. Pedja |
#16 |
Hello,
I have a used transport/optical assembly from a Marantz CD63 that I will sell or trade. It works fine on CDR discs. It does have some sound deadening material applied to the sides and top of the transport( this is a good thing) and the only through hole cap on the board has been replaced with an Elna Cerafine. I can take & post pics if needed. Regards KevinLee
#17 |
I removed and partially stripped down the transport mechanism last night, cleaned the lens, the worm gear together with the straight cut gear. Lubed them as well as the slide on the far side. Refitted them and tested as per service manual which Pedja kindly organised for me. I could see what the problem is and it is not as bad anymore (no skipping, jumping etc). As the laser transport tracks up and down its path one can see it sticking slightly at the same place everytime. After a while of doing this it gets smoother. I left it that. It sounds ok. I am going to give Ken Ishiwata a talking to about putting this cheap and nasty Philips transport into one of his players. I have the model cdm12.1/05 on my transport.
#18 |
Amazing how good it sounds now after fiddling a little with a cotton tip on the lens...am I imagining it or would it be possible?
Cheers, Tom |
| WTB Marantz CD63/67 | Mindcrime | Swap Meet | 6 | 30th January 2009 12:35 PM |
| Marantz CD63 and Headphones | Megamicron | Digital Source | 5 | 25th January 2009 12:02 AM |
| Marantz CD63 | palucca | Digital Source | 3 | 27th September 2008 11:10 PM |
| Marantz cd63 ki no display | paul_peraic | Digital Source | 2 | 25th May 2008 05:22 PM |
| Marantz cd63: PWM to DSD ? | ash_dac | Digital Source | 0 | 24th February 2006 09:59 PM |
| Page generated in 0.08828 seconds (76.22% PHP - 23.78% MySQL) with 10 queries |
