diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   SWAPPING CDM-1 FOR CDM-0 IN PHILIPS CD-101 (http://www.diyaudio.com/forums/digital-source/238034-swapping-cdm-1-cdm-0-philips-cd-101-a.html)
isitrisky 22nd June 2013 06:38 AM
I swapped the CDM-! transport in my Philips cd101 with a CDM-0. The swap went smooth. Player played for a few tracks then blew a fuse. And it won't stop blowing the fuse. Anyone know why it might be doing this. Also the heat sink gets awfully hot. Could it be a bad ground? Thanks in advance.
isitrisky 30th June 2013 08:23 PM
bump
lcsaszar 1st July 2013 12:32 PM
CDM-0 and CDM-1 are compatible. There are many variants, but the external connections are the same. I found the manual at the hifiengine site.
Which fuse is blown, which heatsink is hot? There might be a short in the +12V or -12V rails. You can try disconnecting the turntable motor to see if its associated circuit has a short. Maybe you can transplant the PCBs one-by-one from the CDM-1 to the CDM-0 or vice versa, keeping the known good part: mechanism with swingarm, laser diode, laser PCB, turntable motor PCB with the motor. I think all they are interchangeable between CDM-0 and CDM-1. Only difference is the diecast CDM-1 vs. the steel plate CDM-0 chassis.
Resources saved on this page: MySQL 18.75%
