Sony KSS 165 A - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th June 2013, 08:06 PM   #1
Default Sony KSS 165 A
My discman SONY D 250 bought in the 80's has some trouble : CD is turning, optical block is moving , lense is gowing up and down but after few seconds CD stops. I think the system cannot focus because the laser beam is too weak.
Tjhe optical block is a KSS-165A.
Does somebody know where I can buy that item ?
If it is obsolete, is it possible to change only the laser diode itself ?
Old 19th June 2013, 10:35 PM   #2
SonyES is offline SonyES  United Kingdom
From what I have seen and asuming that the part number is 8-848-096-11 looking on encompass parts there is a substitute/alternative part of 8-848-162-11 Kss-221a.
found one here OPTICAL PICKUP KSS221A/165A [KSS221A/165A] - US$20.00 : Alltronic, One Stop Online Shopping
Old 20th June 2013, 03:08 PM   #3
I have already asked Alltronic but that item is no more available.
Anyway thank you for your quick answer.
Old 20th June 2013, 07:20 PM   #4
Have you tried tweaking the pot on the back of the optical block, marking first your start point then trying different settings, also a deep clean of the lens might help a little.
Old 21st June 2013, 05:26 PM   #5
Here attached some pictures of theKSS165A. The "pot" you mean is it that one circled in red on the 2nd picture ?
Old 21st June 2013, 10:23 PM   #6
That is indeed the one
Old 23rd June 2013, 11:27 AM   #7
Mooly's Avatar
The last three digits of the pickup serial number show the correct (original) current. Is it 419 ? That would be 41.9 milliamps and is checked by measuring the volt drop across a resistor in the laser power circuit on the main PCB and calculating the current. If it is higher than stated by 10% or more then the laser has deteriorated.
Old 23rd June 2013, 02:36 PM   #8
Yes it is 419. I checked the current - as stipulated in the service manual - and I found 41.7 mA which is inside the tolerance (41.9 +/- 10 percent). Therefore the laser diode seems to be OK but - compared to another CD player - the laser beam is very weak.
Old 23rd June 2013, 03:09 PM   #9
On the picture the laser beam of a DVD/CDplayer is clearly defined. But the laser beam of my discman D-250 is practically unvisible. If the laser is OK what could be the reason of the weakness of the beam ?
Old 23rd June 2013, 03:10 PM   #10
Oups I forgot the laser picture...
KSS-190A (Sony 557ESD/707ESD) Netcrusher Digital Source 4 13th April 2014 08:23 AM
KSS-210A (= KSS-150A Successor) and KSS-212A - what is the main difference? tiefbassuebertr Digital Source 5 7th June 2013 09:00 PM
Sony KSS-152 Replacement crackerkorean Digital Source 8 13th February 2012 08:21 AM
Samsung SOH Series - comtatible to Sony's KSS-Series like KSS-213C or KSS-210A? tiefbassuebertr Digital Source 4 6th December 2011 02:56 PM
SONY KSS-213C help fastvideo Digital Source 1 30th July 2010 12:38 PM
Copyright 1999-2017 diyAudio
