ESI Juli@ as external DAC - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th June 2013, 08:43 AM   #1
Post ESI Juli@ as external DAC
Hello,
I managed to mod my ESI Juli@ so that I can use it as an external DAC (with 8 SPDIF/TOSLINK inputs). The problem is that I forgot the output impendance should be at least 100 ohm and I used 32 ohm headphones for testing. The thing is that the right channel of the balanced outputs is fine, all the other (left channel and left/right RCA outputs) have a very low signal level (the DAC is configured with 0dB attenuation).
Do you think I busted the op-amps or there is something else wrong?
Old 13th June 2013, 07:21 AM   #2
I figured it out. It seems that every output (maybe input also) has a transistor that mutes it. The problem is that I couldn't figure out where is the command given from so I removed the transistor completely and everything works well now.
ESI Juli@ - optic digital output (96kHz) TJF PC Based 4 23rd February 2010 07:53 AM
Wtb:ESI Juli@ Nikola Krivorov Swap Meet 1 14th July 2009 06:25 PM
M-Audio Audiophile 192 or ESI Juli ? LinuksGuru Digital Line Level 1 12th April 2009 10:24 AM
Anyone modified an ESI Juli@ here? cynric Digital Source 0 20th November 2007 10:46 PM
ESI Juli schematic wanted annex666 Everything Else 0 20th July 2006 03:34 PM
Copyright 1999-2017 diyAudio
