Problem with Krell KAV 250 CD MkII Problem with Krell KAV 250 CD MkII - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th June 2013, 09:25 AM   #1
bretohne is offline bretohne
Default Problem with Krell KAV 250 CD MkII
Hello,
I am looking for a shematic for the player above, requests for Krell run naturally into vacancy.
The following problem:
The charge is now running again and pulls the CD also.
Laser also drives up 3x and then up and down and
tried to focus. However, the spindle motor is not rotating, the motor I measured with external power and it works. The IC 102 is probably responsible for the spindle motor.
Without switching the whole plan is pretty unproductive,
no voltage specifications, test points.
A cow stood in the mist, because they no longer found.
I hope you can help me.
Best regards
Peter
Old 11th June 2013, 12:24 PM   #2
Mooly's Avatar
The spindle motor won't rotate until focus is found. Primary suspect would probably be the laser pickup.
What is the significance of a "cow standing in the mist" ? I'm sure you understand my curiosity
Old 11th June 2013, 03:30 PM   #3
Hi Mooly,
Disorientation, no approach to problem solving.
Old 11th June 2013, 04:43 PM   #4
Hi Mooly,
It is true that the laser is focused first and he then signal for the spindle motor outputs on the processor, which turns only? When the laser is defective, that is, the signal flow is interrupted?
best regards
Peter
Old 11th June 2013, 06:14 PM   #5
Mooly's Avatar
The sequence of events is,
1) Laser on
2) Focus search initiated (lens going up/down)
3) Processor waits for FOK "focus OK" signal at which point the spindle motor is kicked to approx. correct speed.
4) The disc servo takes over and locks the speed of the disc by comparing the data rate off the disc to a known reference... the master oscillator in the player.
So yes, laser defective and the flow is interrupted.
Old 12th June 2013, 06:34 PM   #6
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
bretohne Offline
RE: Krell KAV 250 CD MkII
Hallo Andreas,
verbaut ist ein CEC TL51Z mit einem
Sanyo SF-P1 Laser, vielleicht hast Du ja einen SF-P1
rumliegen.
Beste Grüsse
Peter
check out this threads:
Yba cd2 delta, classe cdp .3, roksan caspian ... main board
CEC TL51X CD Transport
Krell KAV-250CD Transport Issues
Krell KAV-250CD mk2
Krell KAV-250cd Output stage drawn
Problem with Krell KAV 250 CD MkIIHide this!Advertise here!
Krell KAV-250CD Transport Issues PentAmateur Digital Source 7 7th July 2012 08:36 PM
Take a picture of your Krell KAV-300i please? egeriis Solid State 7 24th January 2012 07:55 AM
KRELL KAV 300I Schematic Anyone ? vdavidov Solid State 10 5th December 2011 02:15 PM
Krell KAV-250CD mk2 eradoncic Digital Source 8 21st September 2010 04:58 AM
Discrete DAC in Krell KAV 300CD Ruach Digital Source 5 16th April 2007 02:56 AM
Copyright ©1999-2017 diyAudio
