Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Help! Kwak Clock - Partial adoption
Old 5th December 2003, 06:21 PM   #11
Lars Clausen is offline Lars Clausen  Denmark
Yes .. 4 times
Old 5th December 2003, 06:24 PM   #12
Bricolo is offline Bricolo  France
Bricolo's Avatar
I can have micas, but a pack of 5 for 15, so 30 for only 2 caps I'll use
I'll stay with the ceramic
BTW, thanks for the advices
Old 5th December 2003, 08:29 PM   #13
Jocko Homo is offline Jocko Homo  United States
Banned
Default Just one problem.......
He never mentioned what frequency it operates at. Kinda hard to give the right advice without knowing that.
But what do I know?
Jocko
Old 5th December 2003, 08:37 PM   #14
Jocko: Doesn't really matter, as long as the xtal has a defined serial capacitance (typically 15 - 30 pF) the frequency of the xtal does not influence the values these two capacitors should have.
And if they are 68 and 39 pF defined by ELSO KWAK i will trust this to be the right values for his version of a Collpitts oscillator.
Have a nice day ..
Old 6th December 2003, 01:34 AM   #15
Banned
Yes, it does matter.
The ratio remains fixed, but the values change as a function of frequency.
Also, it is not spec'ed as whether or not resonance is measured with a series or parallel load. Probably parallel, since most CDPs are that scheme.
But if it is 16 MHz......the load is most likely 20 pF, not 32 pF.
Jocko
Old 6th December 2003, 03:34 AM   #16
overmind is offline overmind  Singapore
overmind's Avatar
Default Re: Just one problem.......
But what do I know?
Jocko
The frequency is 16.9344 Mhz.
Have a nice day ..
If I can remember is the series capactance of the crystal is 30pF. Both 68 and 39 pF cap are silver mica.
The 0.01uF cap between R1 & R2 is a SMD ceramic cap.
Old 6th December 2003, 01:18 PM   #17
The capacitance value is related to the xtal's manufacturing specifications, not the frequency of the oscillator.
Old 6th December 2003, 01:21 PM   #18
Overmind:
Looking at your schematic, it seems there are no resistors to drop the voltage from the 8V ragulator to the 5 and 5.9 V shunts. Are you relying on the series resistance of the chokes?
Did you check the voltages over the shunts, to make sure none of them are burnt?
Good luck ...
Old 6th December 2003, 01:26 PM   #19
Bricolo's Avatar
I would feed the 431s with a constant current source, rather than with a voltage reg
Old 6th December 2003, 02:09 PM   #20
overmind's Avatar
I was informed Cs of the crystal is 30pF.
Overmind:
Good luck ...
I am using the DCR of the inductor to drop the voltage from 8 to 5 and 5.9V. I did not measure the voltage across the inductor. However I am able to measure 5 and 5.9V at the cathode of the LM431s. I think this is ok.
The KC was working till I added in the 5.9V regulator for the AD8561 and change a few resistors.
SW
Help! Kwak Clock - Partial adoptionHide this!Advertise here!
My Kwak Clock 7 zygibajt Digital Source 12 28th November 2010 02:37 PM
49.152 MHz Kwak clock okkyn Digital Source 0 10th July 2007 02:53 AM
optimising kwak clock ced Digital Source 20 26th August 2004 06:04 AM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
help with Kwak-clock jarthel Digital Source 5 4th May 2002 04:16 PM
