Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Oscilloscope issue
Oscilloscope issue
Old 2nd June 2013, 06:10 PM   #1
nuryev is offline nuryev  Australia
Default Oscilloscope issue
Thanks to all who suggested trouble-shooting strategies for CD63KI audio drop out. After checking the player's RF using a 20mhz Aron scope, the problem still persists.
I now have a GW Instek 653 (50Mhz) oscilloscope that may or may not have a fault. While the 20mz scope is able to generate a clear eye pattern for the player, the 653 only generates the section of the pattern to the right of section which indicates the triggering status. ( I hope this makes sense). I have tried adjusting the controls to resemble the older 20mhz but still the extreme left of the eye pattern is not displayed. I have attached pics.
Any advice will be appreciated.
NYV
Old 2nd June 2013, 06:17 PM   #2
R.I.P.
post a pic showing the switch settings.
regards Andrew T.
Old 4th June 2013, 06:53 AM   #3
gmphadte is offline gmphadte  India
Check the trigger settings and horizontal trace should be slowed down.
Gajanan Phadte
Old 4th June 2013, 01:27 PM   #4
Default Swith settings
Switch settings pic attached. Thanks for the suggestion gm. I will check them.
NYV
Old 4th June 2013, 02:28 PM   #5
lcsaszar is offline lcsaszar  Hungary
Try CH1: 0.2 V/div, AC coupled. Trigger AC, norm. Time x10 mag do not push. Horiz display A. Adjust trig level until you get a trace, then adjust Time until you see the eye pattern.
Old 4th June 2013, 03:00 PM   #6
Thanks oshifis, I have followed your clear instructions but only get a display on auto, all adjustments on Trigger AC, norm display a black screen with an odd flash of green when I turn the Time adjuster.
NYV
Old 4th June 2013, 04:01 PM   #7
macboy is offline macboy  Canada
It definitely looks like it is not triggering, try adjusting the trigger level manually, to be around zero volt with positive edge. But it is a little hard to tell, since the 2nd photo is so small and blurry.
Sometimes when a trigger is set to "auto", and the scope can't trigger, it will free-run, meaning it just triggers randomly and repeatedly so that you can at least see that there is a signal being input.
p.s. this thread probably should have been started in "Equipment & Tools".
Old 4th June 2013, 11:59 PM   #8
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
Horizontal position?
Old 6th June 2013, 04:17 AM   #9
Sometimes, you may be successful by adjusting trigger holdoff.
Gajanan Phadte
Oscilloscope issueHide this!Advertise here!
Oscilloscope dipolar Parts 6 27th June 2012 02:12 PM
Small issue with Rigol Oscilloscope probe dimkasta Equipment & Tools 4 25th April 2012 09:16 AM
Debugging oscilloscope issue. slomatt Equipment & Tools 11 6th October 2011 07:55 AM
oscilloscope garry madge Everything Else 3 28th October 2010 05:40 PM
Oscilloscope use. argonrepublic Parts 1 21st January 2006 07:00 AM
