Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Building a silent audio PC. First attempt.
Old 19th May 2013, 01:10 PM   #1
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Default Building a silent audio PC. First attempt.
After long procrastination i finally built a dedicated audio PC following in general the Zuma recipe Computer Audiophile - Computer Audiophile Pocket Server C.A.P.S. v3 Zuma
Same case, MB and disk and a Nano 150W PS from Streacom. As the processor is a low consumption i3 3220T even the heatsinking arrangement of the Streacom case turned out to be an overkill.
The new PC is headless and replaces a nice Dell notebook feeding a USB dac with optical isolation and fifo reclocking.
So, one may wonder, how does the sound compare to the notebook running the same OS with JRiver 18 using ASIO drivers?
In short it sucks. Not a huge difference, but obviously inferior to what i remembered from the Dell. Latency turned out to be about half compared to the Dell, likely because of the lack of antivurus and other background processes - the Dell is a general purpose PC and no attempt has been made to optimise it for audio.
So, what then?
Plugged the Dell in, listened. Slightly better but definitely not what i remember. Maybe something else in the system has taken a dive. Or it's just one of those days...
The nano PS comes with a gigantic mains brick providing 12v @12.5A. It made me a bit suspicious so i switched it off. Now the Dell is sounding finally normal. It appears the PS is polluting either the room, the mains, or both.
This is what my scope shows with the probe shorted to ground and resting on top of the PS. No electrical connection and purely common mode radiated noise.
Old 19th May 2013, 02:03 PM   #2
analog_sa's Avatar
Just finished listening after replacing the little horror with a bench PS @12.5v. Average current consumption seems to hover around 1.5A.
And what a difference! There is ambience, dynamics, hf details galore. Tomorrow will be building a linear supply. So, even with a nasty little switcher supplying the ATX voltages out of the incoming 12v, the raw dc still makes a huge difference, at least in my system and to my ears.
This exercise seems to prove (to me if to no one else ) the importance of clean power compared to the absence of fans and hard disk drives and the reduced latency.
Old 19th May 2013, 03:54 PM   #3
Torchwood421 is offline Torchwood421  United States
Default Computer audio server
Hi analog_sa, Great info. I'm considering doing that, moving to a computer based music system. My experience with switchers is that they are really noisy. Has anyone ever ran a computer on linear supplies for audio? I think your on to something here. Dave
Old 19th May 2013, 07:35 PM   #4
analog_sa's Avatar
No, i am not Just sharing some personal observations. All this has been done before. Red Wine Audio per example sell a lithium battery system for powering PCs. Not cheap.
Of course, even though supplying cleaner power to a switcher seems to make a pronounced difference in my case, it is much better to get rid of the "nano", "pico", or whatever other switchers generate the ATX supplies out of the incoming 12v and instead source the required voltages from linear supplies. For a low power system, such as the one i use it is not hard. The problem is that most motherboards are fussy about the sequence of applying the various voltages, so some intelligence may be required for the PS.
Detractors are always fast to point out that in any case some switchers will still be left on the mobo itself. Probably too hard to bypass those. It seems though that motherboards are designed to keep switcher interference well controlled, while external switchers are much more damaging.
Old 22nd May 2013, 08:52 AM   #5
analog_sa's Avatar
This is getting a bit frustrating. To recap what is being compared:
1. Dell XPS i5 Win 7 64 laptop
2. i3 3220t in a fanless case with SSD Win 7 64, power for ATX12v is supplied from a little switcher board called "nano" from incoming 12v.
Replacing the original 12v switching supply with a bench supply brought considerable improvement to the silent PC. Replacing that with a linear supply using a 1084 regulator and plenty of good capacitance brought a lateral change, rather than improvement.
Dell laptop still sounds better overall, which tbh is rather annoying. I see three options right now
- nano is a useless POS with excessive noise level. It would be a good idea to replace it with a low noise standard ATX supply for a test only atm i don't have a free one. Ideally the whole lot should be powered from linear supplies but that is definitely not a weekend project
- despite prevailing theories a low power processor is just not sufficient. There is a low consumption i7 which seems like a good candidate.
- motherboard is cursed by the audio gods and will never sound good. Time for attempt N2
Old 22nd May 2013, 12:38 PM   #6
marce is offline marce  United Kingdom
Interesting point, yes local on board SMPS's should be laid out properly and to the device data sheets, plus they are much smaller than the main computer SMPS's. Also a lot of the main supplies can leave a lot to be desired in both quality and EMC compliance, we once shipped a container load over and ended up skipping them because of the emissions. A good quality SMPS on the front end will be no different than a linear supply for resultant noise though, as a lot of PC electrical noise is created by the PC its self and the logic switching.
Again on motherboards and local supplies a good design will only have 2 SMPS's one after the other, then for the lower current local supplies use LDO's.
DELL generaly seem to be good quality, we use them in the CAD department for reliability.
Old 22nd May 2013, 01:48 PM   #7
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Neat idea. Should switch out that noisy nano psu with a couple of these in parallel.
Tenergy 12.8V 10Ah LiFePO4 Stick Battery Pack with PCB
Old 22nd May 2013, 03:00 PM   #8
analog_sa's Avatar
Replacing the 12v dc with batteries is something i can relatively easily try out. I can see that compared to a linear supply it will help by limiting the RF hash of the nano going back into the mains and providing connecting wires are screened, also limiting radiated HF. But it will not in any way improve what the nano does to the pc supplies.
It may, of course turn out that the real problem is not how much the pc rails get polluted, but rather RF contamination of external audio components.
Old 22nd May 2013, 03:07 PM   #9
You should use an usb isolator (for your dac). Get some test results, I'd like to see them.
Old 22nd May 2013, 05:25 PM   #10
analog_sa's Avatar
I have an isolator on the i2s side followed by a fifo and a reclocker (Ian's fifo) . Theoretically, there is no possible way the transport side can affect the sound. From what i know, there is only one option available as USB isolator Adnaco-S3B – USB 3.0 Over Fiber Optic Expansion System. I am not at all sure it will work with the EXA usb board.
What test results? I guess i could measure PS rail spectra with different supplies. How meaningful is that?
Building a silent audio PC. First attempt.Hide this!Advertise here!
Second attempt at Building my own amp from scratch Vostro Solid State 106 9th May 2014 01:21 PM
Building a Silent Rehearsal Studio, and need answers. lotyboy Everything Else 12 31st December 2010 12:47 AM
TQWT Concrete cabinet attempt, building thread. h@kan Full Range 28 16th July 2010 04:23 PM
Diy Silent PC Power supply geminni Power Supplies 15 10th July 2009 01:57 PM
Silent switching for XLR audio switcher Smeltis Solid State 0 31st March 2006 01:02 AM
Copyright ©1999-2017 diyAudio
